  2. Local Shops and Businesses
  3. Trafik Jamz
  4. CarPC
CarPC
Scheduled Pinned Locked Moved Trafik Jamz
26 Posts 9 Posters 11.5k Views
  • 63vette6
    63vette6
    63vette
    • T
      T
      Trafik Jamz
      It's a computer running Windows XP...figured that part would tell you that so long as the datalogging software works on Windows XP, it will work on that as well. My laptop doesn't say anything about datalogging either, and it works just fine.
      But since some people can't read between the lines this is a PC that:
      Turns on/off with your car
      Has on board bluetooth
      On board WiFi that can connect in wifi hotspots
      Is capable of tethering to your phone/air card via USB allowing for broadband internet service
      Allows movie and audio storage on its internal HDD
      48KHz 16-bit Stereo Sound - Far superior to Bluetooth Audio
      Allows video playback to headrest monitors/drop down monitors/In Dash Monitors/etc... so the whole family can enjoy it
      Supports games/activities that are actually fun to play for longer than 5 minutes
      Is capable of supporting Outlook/Office/Etc... so that files can be viewed on a larger screen, reminders can be displayed, and contacts can be accessed easier than on a tiny little phone screen
      Can be set up to sync with your blackberry/smartphone/droid/whatever
      Again, it is a full blown pc, just add monitor.
      If it's not your bag of chips, why come in here and comment? Do I come to your place of business and put up signs saying your products/services are pointless? I just ask the same in my online business location.
      Thanks.
      701.541.3484
      • 63vette6
        63vette6
        63vette
        • T
          T
          Trafik Jamz
          I'm not upset at all, I can validate virtually any purpose of this product. If I were all upset I'd delete your posts and issue a warning via the admin panel. By you asking questions it gives me a chance to rebut/clarify it's purpose.
          701.541.3484
          • 63vette6
            63vette6
            63vette
            Sounds like a great product! heh. All better.
            • T
              T
              Trafik Jamz
              lol
              701.541.3484
              • T
                T
                Trafik Jamz
                Bump! Getting about 6 of these in in the next week or so (hopefully), will throw in a free bluetooth keyboard and mouse as well ($150 value)
                701.541.3484
                • ruthless351R
                  ruthless351R
                  ruthless351
                  Sounds like a good deal to me!
                  • PSiedTSiP
                    PSiedTSiP
                    What kind of processing power does this have? I know I would be more apt for something like this if I knew it could play bluray files smoothly. I know my older Athlon with a geforce card struggles with HD content. There are obvious advances these days, so just kind of curious. I'd assume most people won't try anything like that either.
                    spanish-rice;237125 wrote:
                    • T
                      T
                      Trafik Jamz
                      Bluray...no disc drive
                      Here are the specs, its not an uber machine by any means, but it will do what it is intended to do extremely well
                      SUPPORT: SPECIFICATIONS
                      Hardware:
                      • 1GHz Intel Celeron
                      • 512MB of RAM
                      • Intel 855 Chipset
                      • Bluetooth 2.0
                      • Wi-Fi 802.11b/g
                      • 5 Hi-Speed USB 2.0 Ports
                      • Composite Video Output – Compatible with most car video systems
                      (Excl. Certain OEM Installs with no video input)
                      • 48KHz 16-bit Stereo Sound
                      • Shock-Mounted Automotive-Grade Toshiba 40GB Hard Drive
                      • Wired Ethernet Port for installation in vehicles with a wired network such
                      as RVs & Busses
                      • Line Input connection for external audio sources
                      • Custom 12V Automotive Power Supply
                      • Remote-Mounted power switch for convenience
                      Capacities:
                      • 10,000 Songs
                      • 50 Hours of Video
                      • 40,000 Photographs (Medium Resolution)
                      • 20,000 Photographs (High Resolution)
                      Software:
                      • Powered by StreetDeck
                      • Runs Genuine Microsoft Windows® XP – Compatible with most applications
                      • Windows Media Player® 11
                      • 3ivx Codec
                      Chassis:
                      • Dimensions:
                      • Height: 44mm (38mm excluding feet)
                      • Width: 206mm
                      • Depth: 134mm (Excluding connectors and antennas)
                      • Weight: 1.00kg
                      • Material: Die-Cast Aluminum
                      Power Consumption
                      • 1.5amps
                      701.541.3484
                      • JimJ
                        JimJ
                        Do these use SSD or just a standard drive?
                        • T
                          T
                          Trafik Jamz
                          I think standard, but might be wrong.
                          701.541.3484
                          • PSiedTSiP
                            PSiedTSiP
                            My guess would be standard if it's shock mounted. Good deal tho, especially for someone thats looking at getting an indash.
                            • PhatsP
                              PhatsP
                              Phats
                              Weird, i know, but what about FM? I would still like that option..... also were the improvements/modifications done for the awesome weather we have here? i mean it could be -15 and warm up to 50 to 60 in a hour or so, wouldn't that typically be a issue?
                              Just curious Thanks for the info.
                              02 GSXR-1000
                              97 540i
                              • T
                                T
                                Trafik Jamz
                                Environment won't be an issue, as for AM/FM radio: http://www.mp3car.com/vbulletin/car-audio/33707-radioshark-am-fm-usb-adapter-timeshifting.html
                                701.541.3484
                                • S
                                  S
                                  Stärke
                                  Hey, this is neat stuff.:icon_rabbit:
                                  '00 Chevy RCSS 4x4 - '81 Suzuki GS750L - '82 Yamaha Virago XV750 (winter project) - Scroogle
                                  "No dumb bastard ever won a war by dying for his country. He did it by making the other dumb bastard die for his country." - General George S. Patton
                                  • F
                                    F
                                    Flyinsupra
                                    I suppose this would work with a stock nav screen?
                                    • T
                                      T
                                      Trafik Jamz
                                      if it has an auxiliary input (stock nav screen), it should work fine
                                      701.541.3484
