  2. Local Shops and Businesses
  3. Trafik Jamz
  4. CarPC
CarPC
Scheduled Pinned Locked Moved Trafik Jamz
26 Posts 9 Posters 11.5k Views
  • 63vette6
    63vette6
    63vette
    • T
      T
      Trafik Jamz
      I'm not upset at all, I can validate virtually any purpose of this product. If I were all upset I'd delete your posts and issue a warning via the admin panel. By you asking questions it gives me a chance to rebut/clarify it's purpose.
      701.541.3484
      • 63vette6
        63vette6
        63vette
        Sounds like a great product! heh. All better.
        • T
          T
          Trafik Jamz
          lol
          701.541.3484
          • T
            T
            Trafik Jamz
            Bump! Getting about 6 of these in in the next week or so (hopefully), will throw in a free bluetooth keyboard and mouse as well ($150 value)
            701.541.3484
            • ruthless351R
              ruthless351R
              ruthless351
              Sounds like a good deal to me!
              • PSiedTSiP
                PSiedTSiP
                What kind of processing power does this have? I know I would be more apt for something like this if I knew it could play bluray files smoothly. I know my older Athlon with a geforce card struggles with HD content. There are obvious advances these days, so just kind of curious. I'd assume most people won't try anything like that either.
                spanish-rice;237125 wrote:
                • T
                  T
                  Trafik Jamz
                  Bluray...no disc drive
                  Here are the specs, its not an uber machine by any means, but it will do what it is intended to do extremely well
                  SUPPORT: SPECIFICATIONS
                  Hardware:
                  • 1GHz Intel Celeron
                  • 512MB of RAM
                  • Intel 855 Chipset
                  • Bluetooth 2.0
                  • Wi-Fi 802.11b/g
                  • 5 Hi-Speed USB 2.0 Ports
                  • Composite Video Output – Compatible with most car video systems
                  (Excl. Certain OEM Installs with no video input)
                  • 48KHz 16-bit Stereo Sound
                  • Shock-Mounted Automotive-Grade Toshiba 40GB Hard Drive
                  • Wired Ethernet Port for installation in vehicles with a wired network such
                  as RVs & Busses
                  • Line Input connection for external audio sources
                  • Custom 12V Automotive Power Supply
                  • Remote-Mounted power switch for convenience
                  Capacities:
                  • 10,000 Songs
                  • 50 Hours of Video
                  • 40,000 Photographs (Medium Resolution)
                  • 20,000 Photographs (High Resolution)
                  Software:
                  • Powered by StreetDeck
                  • Runs Genuine Microsoft Windows® XP – Compatible with most applications
                  • Windows Media Player® 11
                  • 3ivx Codec
                  Chassis:
                  • Dimensions:
                  • Height: 44mm (38mm excluding feet)
                  • Width: 206mm
                  • Depth: 134mm (Excluding connectors and antennas)
                  • Weight: 1.00kg
                  • Material: Die-Cast Aluminum
                  Power Consumption
                  • 1.5amps
                  701.541.3484
                  • JimJ
                    JimJ
                    Do these use SSD or just a standard drive?
                    • T
                      T
                      Trafik Jamz
                      I think standard, but might be wrong.
                      701.541.3484
                      • PSiedTSiP
                        PSiedTSiP
                        My guess would be standard if it's shock mounted. Good deal tho, especially for someone thats looking at getting an indash.
                        • PhatsP
                          PhatsP
                          Phats
                          Weird, i know, but what about FM? I would still like that option..... also were the improvements/modifications done for the awesome weather we have here? i mean it could be -15 and warm up to 50 to 60 in a hour or so, wouldn't that typically be a issue?
                          Just curious Thanks for the info.
                          02 GSXR-1000
                          97 540i
                          • T
                            T
                            Trafik Jamz
                            Environment won't be an issue, as for AM/FM radio: http://www.mp3car.com/vbulletin/car-audio/33707-radioshark-am-fm-usb-adapter-timeshifting.html
                            701.541.3484
                            • S
                              S
                              Stärke
                              Hey, this is neat stuff.:icon_rabbit:
                              '00 Chevy RCSS 4x4 - '81 Suzuki GS750L - '82 Yamaha Virago XV750 (winter project) - Scroogle
                              "No dumb bastard ever won a war by dying for his country. He did it by making the other dumb bastard die for his country." - General George S. Patton
                              • F
                                F
                                Flyinsupra
                                I suppose this would work with a stock nav screen?
                                • T
                                  T
                                  Trafik Jamz
                                  if it has an auxiliary input (stock nav screen), it should work fine
                                  701.541.3484
