  4. Oil Catch Can???
Oil Catch Can???
4 Posts 2 Posters 560 Views
  • 95_gsr_swap9 Offline
    95_gsr_swap
    Ok, so I've been doing some research on what the purpose of an oil catch can is for, but Im thinking they are more of a cosmetic object than something that will actually benifit me. So if anyone knows anything about these and if there recomended please make a comment because im quite curious.
    Thanks
    92 Honda Civic VX 1.5l vtec-e - SOLD
    86 Toyota Corolla - Project
    B18C1 Boost Project Soon To Be Done Once Home - SOLD
    92 civic coupe b18b swap
      If your not boosted then the chances of you needing one are very slim. They let excess pressure bleed for the crankcase.
        95_gsr_swap
        Ok, so the deal is, I'm trying to get all my parts together for the build, so it goes quick when I get home. As for boosting, that is the plan. I'm gonna be trying for the 300hp range and I guess I'm trying to figure out if I'm gonna need one.
          Well doing it in a way that isn't a waste of time isn't cheap, the fittings get expensive quick. You need a catch can that is vented and has a drain back unless you want to drain it yourself. (can run the risk of dumping all your oil into the can and overflowing it or running low on oil).
          pm me if you interested in this more.
