  4. Subaru help
Subaru help
13 Posts 6 Posters 1.1k Views
  • wa2fastcamaroW
    wa2fastcamaroW
    wa2fastcamaro
    My bosses wife has a 2005 baja with lil over 50K miles on it. About 2 weeks ago it started acting up when you turn corners, its starts hopping and makes noise. Kind of like trying to make a really sharp turn with a truck in 4wd. Does not act up going straight or small turns. Checked all the cv's and there good, kind of confused now. No local shops have any idea either and the dealer would give me any help. any ideas since there are some many local subaru people?
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
    • gsrEKG
      gsrEKG
      gsrEK
      i have replaced a couple diffs in the rear on some subaru's for axle problems and making weird noises
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      BlackEJ8;233529 wrote:
      • PSiedTSiP
        PSiedTSiP
        Center diff?
        spanish-rice;237125 wrote:
        • FG2F
          FG2F
          FG2
          check diffs. Drain fluid, look at contents, replace with a better fluid if no visible damage.
          • wa2fastcamaroW
            wa2fastcamaroW
            wa2fastcamaro
            we changed the diff fluid about 3K miles ago as normal maintenance. What would you guys suggest for brand or kind of diff lube?
            Phone: 701-371-5615
            • RexwagonR
              RexwagonR
              amsoil sevre gear. you can get it at fleet farm. make sure to check the center diff. if its a manual all the fluid is together, if its auto they are seperate. if its auto you dont need to drain the transmission for this problem. but if you do, you need to use special trans fluid from subaru, not any regular atf will do.
              to me the problem sounds like a diff issue.
              maybe the transfer clutch on the center diff is bad.
              • RexwagonR
                RexwagonR
                http://www.subaruforester.org/vbulletin/f70/turning-full-lock-shuttering-shaking-normal-52872/
                • PSiedTSiP
                  PSiedTSiP
                  ...did you make sure you put in the right kind? I don't much about the subaru diffs, but I think they have some kind of Viscous or Helical LSD no?
                  • RidinRailsR
                    RidinRailsR
                    some not all have helical lsd's...
                    • wa2fastcamaroW
                      wa2fastcamaroW
                      wa2fastcamaro
                      I filled the car with fluids recommended by the owners manual. Did some testing yesterday, there is a awd fuse spot in the under hood fuse center, had no fuse in it, and found in the internet that if you install a fuse it puts the car in fwd mode. Well after installing the fuse, the ad light turns on in the gauge cluster and test driving it shows no problem, so that at least narrows it down.
                      Phone: 701-371-5615
                      • RexwagonR
                        RexwagonR
                        Its probably the center diff then. $$$$$$$$$
                        • wa2fastcamaroW
                          wa2fastcamaroW
                          wa2fastcamaro
                          fun, well i will pull it apart eventually. Shes just going to drive in in fwd mode only for the time being until I know enough of what to do to fix the center diff.
                          Phone: 701-371-5615
                          • RexwagonR
                            RexwagonR
                            is it auto or manual?
                            if its auto its a seperate unit (easier to replace) i do believe. If its manual its inside the transmission and from what I hear, just replace the whole unit.
