  4. BOOTMGR is missing...win 7
18 Posts 8 Posters 1.7k Views
  • darkelvisD
    darkelvisD
    darkelvis
    Anyone have a windows 7 disc so I can fix this problem ASAP? Dell isn't nice enough to include one with new computers apparently. God damn computer is 2 months old and this bullshit happens. Not very happy right now.
    • amichezeA
      amichezeA
      Does it matter which version?
      Fargostreet Trolls wrote:
      i must be stupid
      • darkelvisD
        darkelvisD
        darkelvis
        It shouldnt
        • YellowEvoY
          YellowEvoY
          YellowEvo
          dont think I got a disc with my Lenova either...
          2003 Mitsubishi Evolution 8
          2011 Ford F150 Ecoboost
          • SmitEvoS
            SmitEvoS
            I think usually you have to pay to get the back up disc...I paid $10 I think for XP on my Dell years ago. Maybe that option doesnt exist anymore.
            • MisterCMKM
              MisterCMKM
              Usually you burn your own recovery discs after you first turn on the computer...
              thrash;315544 wrote:
              Ford is back :)
              • darkelvisD
                darkelvisD
                darkelvis
                Bootmgr isn't on my recovery disk
                • MisterCMKM
                  MisterCMKM
                  You need the recovery discs to access the system repair tools to fix Windows Boot Manager (bootmgr).
                  http://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
                  You can order the recovery media from that link. You will have to wait for the discs which doesn't really do you any good right now.
                  To get your machine back up and running now, go here: http://neosmart.net/blog/2009/windows-7-system-repair-discs/
                  Download the applicable flavor of recovery disc and burn it. Then go here: http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
                  Follow those instructions and that should take care of your problem. Hope that helps. :icon_salut:
                  Ford is back :)
                  • ichibankillaI
                    ichibankillaI
                    I might be able to burn you a copy of Win 7 Ultimate, or not. :icon_pirat:
                    • darkelvisD
                      darkelvisD
                      darkelvis
                      thanks CMK. I was trying to find somewhere to download a GOOD recovery/fix file but it was kind of time consuming/not going so well searching on my phone. I'll give that a shot after work tonight.
                      • MisterCMKM
                        MisterCMKM
                        The links that I posted will be easy. It is a piece of cake. Let me know if you need any more help with it.
                        Ford is back :)
                        • O
                          O
                          In my experience, the only solution is to archive your important data and then reinstall. The "bootmgr missing" problem can't be fixed with the recovery console (at least, the one I experienced).
                          +1 for installing the OS in a separate partition with important programs and data in another
                          • amichezeA
                            amichezeA
                            It should be as simple as throwing in the disc and doing a copy 'path on disc' 'path on drive' in the console. At least that solved a similar problem I ran into on a client's machine a while back.
                            If CMK's links don't fix it and all you need is that one file, I can email you a copy of it.
                            i must be stupid
                            • darkelvisD
                              darkelvisD
                              darkelvis
                              cmk's link worked, downloaded the iso on my brother-in-law's slow ass computer, burned an image of it loaded it in my computer and within 5 minutes my porn box was up and running again...thanks for the help!
                              • O
                                O
                                I'll do some looking on my ntfs partition to see where the boot.ini is located, but I seem to recall not finding it anywhere. How that could happen is outside my scope of realistic expectations.
                                • T
                                  T
                                  thrash
                                  boot.ini is not relevant on modern NT machines. A clean Win7 install doesn't have one anywhere.
                                  • O
                                    O
                                    By "modern NT machines", I assume you mean everything after XP? I don't know about Vista, but I know where boot.ini is in XP and how to modify it.
                                    • MisterCMKM
                                      MisterCMKM
                                      Windows Vista, 2008 and 7 use a different boot loader than XP. None of the "solutions" proposed by others in this thread would have worked on the problem that darkelvis was having.
                                      Ford is back :)
