BOOTMGR is missing...win 7
darkelvis;306787 wrote:
Bootmgr isn't on my recovery disk
You need the recovery discs to access the system repair tools to fix Windows Boot Manager (bootmgr).http://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
You can order the recovery media from that link. You will have to wait for the discs which doesn't really do you any good right now.
To get your machine back up and running now, go here: http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Download the applicable flavor of recovery disc and burn it. Then go here: http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Follow those instructions and that should take care of your problem. Hope that helps. :icon_salut:
I might be able to burn you a copy of Win 7 Ultimate, or not. :icon_pirat:
darkelvis;306829 wrote:
thanks CMK. I was trying to find somewhere to download a GOOD recovery/fix file but it was kind of time consuming/not going so well searching on my phone. I'll give that a shot after work tonight.The links that I posted will be easy. It is a piece of cake. Let me know if you need any more help with it.
In my experience, the only solution is to archive your important data and then reinstall. The "bootmgr missing" problem can't be fixed with the recovery console (at least, the one I experienced).
+1 for installing the OS in a separate partition with important programs and data in another
out there;306862 wrote:
In my experience, the only solution is to archive your important data and then reinstall. The "bootmgr missing" problem can't be fixed with the recovery console (at least, the one I experienced).+1 for installing the OS in a separate partition with important programs and data in another
It should be as simple as throwing in the disc and doing a copy 'path on disc' 'path on drive' in the console. At least that solved a similar problem I ran into on a client's machine a while back.
If CMK's links don't fix it and all you need is that one file, I can email you a copy of it.
