  4. Tang Band 8" subwoofer in box
42 Posts 14 Posters 2.2k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    I have built an enclosure for one of these before. I know they are only 8's, but they sound excellent, a lot of bass for the size.
    GLWS
      Looks good, can't wait to get it and put it in... I pretty much never buy audio stuff, but soon as I heard this (blackcherrytsi picked one up and put it in his car, and it was very nice) i just had to have one, so u know it's got to be something nice, lol... It doesn't take up much room at all and hits hard and sounds good...
        Bump!! Building another enclosure tonight. Will bring to Show n Shine on Sat. if anyone's interested
        • dont got a rideD Offline
          dont got a ride
          dont fo get da BILLZ
          2001 2.5rs (project RSTI)
            Oh fo sho
              What are the box dimensions?
                dont forget mine sir, lol
                • blackcherryTSiB Offline
                  blackcherryTSi
                  small enough to fit anywhere... seriously minimum space, maximum bass
                  (unintentional rhyme)
                  1995 Honda Civic
                    24"Long x 11"High x 11"Deep
                      dont got a ride
                      thats what skill is
                      • wishinskyW Offline
                        wishinskyW Offline
                        wishinsky
                        Wes, what are the specs on these? Rms?
                        -Cars i drive
                        2002 Mustang
                        1997 Bravada Smart Track
                        • Toys
                          05 TTR 125 L/LE
                          02 YZ 85 with 110cc kit
                          Trafik Jamz
                          They are HIGHLY efficient 8" subs that don't require a ton of power to be loud, but then again they also don't have a huge power handling (125 to 150ish).
                          Tangband makes excellent equipment and wes builds a mean box. GL w/ sale!
                          701.541.3484
                            What would a good amp be for this setup?
                              blackcherryTSi
                              ive got a cheap V3 400 watt amp on mine and it hits pretty damn good. i wanna step up to 500-600 tho see what it has ha
                              1995 Honda Civic
                                wishinskyW Offline
                                wishinsky
                                Well wes if you have any of these left maybe i will look into one in about a month if you still go it. I can't fit my 15" in the trunk so it needs to go.
                                -Cars i drive
                                2002 Mustang
                                • Toys
                                  05 TTR 125 L/LE
                                  Trafik Jamz
                                  The W8-740 is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers. Specifications: *Power Handling: 150 watts RMS/300 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 28-1,000 Hz *Fs: 28 Hz *SPL: 84 dB 2.83V/1m *Vas: 0.81 cu. ft. *Qms: 10.53 *Qes: .30 *Qts: .30 *Xmax: 12mm *Dimensions: Overall diameter 8-1/4", Cutout diameter 7-1/4", Depth 4-3/4"
                                  701.541.3484
                                    I know where there's an amp that size, just sitting around too 🙂
                                    bump for some sweet bumps...
                                      Rebuild the box for the car?? It's not that difficult...
                                        Well, three down..... 1 to go. Thanks for your business Faber.
                                          Trafik Jamz
                                          The sub box he needs is about 4 cuft+ port volume....so around 5.2 cuft total....that's why it won't fit.
                                          701.541.3484
