  4. Tang Band 8" subwoofer in box
42 Posts 14 Posters 1.9k Views
  • dont got a rideD Offline
    dont got a ride
    dont fo get da BILLZ
    2001 2.5rs (project RSTI)
      Oh fo sho
        What are the box dimensions?
          weshole;307960 wrote:
          Bump!! Building another enclosure tonight. Will bring to Show n Shine on Sat. if anyone's interested
          dont forget mine sir, lol
          • blackcherryTSiB Offline
            blackcherryTSi
            small enough to fit anywhere... seriously minimum space, maximum bass
            (unintentional rhyme)
            1995 Honda Civic
              24"Long x 11"High x 11"Deep
                dont got a ride
                thats what skill is
                • wishinskyW Offline
                  wishinskyW Offline
                  wishinsky
                  Wes, what are the specs on these? Rms?
                  -Cars i drive
                  2002 Mustang
                  1997 Bravada Smart Track
                  • Toys
                    05 TTR 125 L/LE
                    02 YZ 85 with 110cc kit
                    Trafik Jamz
                    They are HIGHLY efficient 8" subs that don't require a ton of power to be loud, but then again they also don't have a huge power handling (125 to 150ish).
                    Tangband makes excellent equipment and wes builds a mean box. GL w/ sale!
                    701.541.3484
                      What would a good amp be for this setup?
                        blackcherryTSi
                        ive got a cheap V3 400 watt amp on mine and it hits pretty damn good. i wanna step up to 500-600 tho see what it has ha
                        1995 Honda Civic
                          wishinskyW Offline
                          wishinsky
                          Well wes if you have any of these left maybe i will look into one in about a month if you still go it. I can't fit my 15" in the trunk so it needs to go.
                          -Cars i drive
                          2002 Mustang
                          • Toys
                            05 TTR 125 L/LE
                            Trafik Jamz
                            The W8-740 is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers. Specifications: *Power Handling: 150 watts RMS/300 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 28-1,000 Hz *Fs: 28 Hz *SPL: 84 dB 2.83V/1m *Vas: 0.81 cu. ft. *Qms: 10.53 *Qes: .30 *Qts: .30 *Xmax: 12mm *Dimensions: Overall diameter 8-1/4", Cutout diameter 7-1/4", Depth 4-3/4"
                            701.541.3484
                              I know where there's an amp that size, just sitting around too 🙂
                              bump for some sweet bumps...
                                Rebuild the box for the car?? It's not that difficult...
                                  Well, three down..... 1 to go. Thanks for your business Faber.
                                    Trafik Jamz
                                    The sub box he needs is about 4 cuft+ port volume....so around 5.2 cuft total....that's why it won't fit.
                                    701.541.3484
                                      Oh and btw..... I have sold to two of the 3 cheapest, tightest mutherfuckers that frequent this site. Brandon and Faber...............
                                      TORBS!!!!! your next.
                                        HA epic!!
                                          lmao, what about poly fill? Doesn't that "spoof" more enclosure space? Hell, just build the trunk into a huge box hahah jk
