  2. Local Shops and Businesses
  3. Trafik Jamz
  4. Amp Help?
Amp Help?
Scheduled Pinned Locked Moved Trafik Jamz
14 Posts 5 Posters 7.5k Views
  • wishinskyW Offline
    wishinskyW Offline
    wishinsky
    C:\Documents and Settings\jacobwishinsky\Desktop\Current (How my sub is wired now).mht
    Lets try this? I need to wire a RE audio sx15" D4 to a 4 channel amp? Any way?
    -Cars i drive
    2002 Mustang
    1997 Bravada Smart Track
    • Toys
      05 TTR 125 L/LE
      02 YZ 85 with 110cc kit
      Trafik Jamz
      Learn how to post pics....then I'll help.
      701.541.3484
        Trafik Jamz
        Bridge Channels 1&2 together and hook them up to ONE voice coil
        Bridge Channels 3%4 together and hook them up to the other voice coil
        Set gains EXACTLY the same on each (no higher than 2/3 of max...EVER) ...set Low Pass Filter to ~90hz
        701.541.3484
          wishinskyW Offline
          wishinsky
          yeah, i was at school and having troubles. It said the pic was to big as well.
          I am just wondering if there is any way to use all the channels on that amp i bought from you and using only 1 sub.
          -Cars i drive
          2002 Mustang
          • Toys
            05 TTR 125 L/LE
            wishinskyW Offline
            wishinsky
            When i do what you said above it kicks my amp into protect once i turn the volume up and it ain't even loud....i am at like 1/3 gain.
            -Cars i drive
            2002 Mustang
            • Toys
              05 TTR 125 L/LE
              Trafik Jamz
              Dual 2 ohm sub IIRC. The amp probably doesn't like being @ 2 ohm mono on that sub (they tend to stay pretty low in their impedance, especially the way that box is designed)...the Type R's you had before probably didn't run that low which is why they worked.....
              701.541.3484
                wishinskyW Offline
                wishinsky
                Yeah and my Type R's i had in a parallel series.... Well this sub don't fit in the car anyways so if i sell it do you recommend me selling the amp to and buying all new again? Or should i keep the amp and just get 2 subs so i can use both the bridged channels? Cuz i will probably buy some 8's or 10's from you once i start working full time in a week.
                -Cars i drive
                2002 Mustang
                • Toys
                  05 TTR 125 L/LE
                  Trafik Jamz
                  do what you want man...its your stuff.
                  701.541.3484
                    Trafik Jamz
                    I'll hook you up should you decide to sell off and start over.
                    701.541.3484
                      wishinskyW Offline
                      wishinsky
                      Yeah...I am going to sell all this stuff and start over fresh. It's always nice knowing your the original owner. Well after i get a couple paychecks in my wallet when school gets out (20th) i will hopefully be able to give you a a good grand, grand and a half or so. And we can figure out a really good setup to put in the stang.
                      -Cars i drive
                      2002 Mustang
                      • Toys
                        05 TTR 125 L/LE
                        wishinskyW Offline
                        wishinsky
                        Hey chuck is there a way to test my amp. I just feel like the front bridge channels arn't putting out the same watts compared to the rear bridge channels.
                        -Cars i drive
                        2002 Mustang
                        • Toys
                          05 TTR 125 L/LE
                          • theobliviousT Offline
                            theoblivious
                            http://www.crutchfield.com/S-lePPiWvmUon/learn/learningcenter/car/subwoofers_wiring.html
                            BOOST....to be continued
                            • naturalbornkellerN Offline
                              naturalbornkeller
