  4. TPMS sensors
TPMS sensors
8 Posts 5 Posters 958 Views
  • MazdaboyM Offline
    MazdaboyM Offline
    Mazdaboy
    I bought some wheels that came with these TPMS sensors they worked for about a month but then the error light started flashing, anyone ever deal with these things before, they are specifically for a Nissan Altima, has anyone ever heard anything about resetting these? Or should i just let em go on ebay?
    • Mazdaspeed3
    • svxALS Offline
      svxALS Offline
      svxAL
      If you have a blinking light this means 1 of 2 things bad sensor or you need to get one reprogrammed they can do this at any dealership
      94 Subaru SVX FWD
      subaru-svx.net
      1999 silverado
      • Puppet MasterP Offline
        Puppet Master
        You said they are specifically or a Nissan Altima so i assume you drive an altima as well. If you dont then it's obvious why they aren't working...but yes, one has probably died or you need them reset...unfortunately for a Nissan you more then likely have to go to the dealer to have the sensors reset.
        • capitljC Offline
          capitljC Offline
          capitlj
          There isn't that many different sensors so I think the ones you have will work with your car however if you never had them programmed that's what the error is. It requires a special tool but pretty much any tire shop should be able to make short work of that.
          > Mitch Hedberg wrote:
          2004 Impala LS 3.8
          • MazdaboyM Offline
            MazdaboyM Offline
            Mazdaboy
            Thanks, I was thinking this as well, I cant imagine that these things run on too many separate frequencies, when I get the tires remounted I'll ask around about them. They came with the wheel and tire set I bought used and since my car utilizes the function, There really isn't any disadvantage to put a little effort into getting the little things to work properly.
            • Mazdaspeed3
            • capitljC Offline
              capitljC Offline
              capitlj
              Nope actually, most places will do that kind of thing anyway when mounting new tires, its nescessary when doing rotations.
              2004 Impala LS 3.8
              • SvenS Offline
                SvenS Offline
                Sven
                One thing that I just ran into was a Honda where the TMPS went off roughly a month after ownership of the aftermarket wheels. The sensors themselves went bad...well, 4 sensors later (and a couple years later) we determined the wheels were actually leaking moisture, causing the sensors to corrode. Super rare, but ask them to check that while mounting just to be safe. By the time we figured it out, it was past warranty for the rims.
                -09 Black Civic Si Coupe I/H/E/Tein S-Tech + FlashPro
                8600RPMs of ridiculously loud fury!
                -88 'Stang 306 Block/Cam/Gears/Pulleys/etc.etc. -SOLD ...then crushed.
                -04 SRT-4 Stage 2/Exhaust/Intake/Suspension/etc.etc. - SOLD ...then exploded.
                Be happy I still don't have that car ^^ You thought my Civic was loud...pfft...
                • MazdaboyM Offline
                  MazdaboyM Offline
                  Mazdaboy
                  Ahh man, should have checked this yesterday, I just had the wheels remounted..should have mentioned it...they looked ok, but we all know how that works, should turn out ok, going to try and reset them today
                  • Mazdaspeed3
