  4. New Stuff
New Stuff
461 Posts 56 Posters 70.9k Views
    Old News.
    Is that a Snow kit?
    • funky_monkey58F Offline
      funky_monkey58
      Sweet fire extinguisher mounting!
        Zac do we get to see this thing this weekend???
          funky_monkey58
          I want to see it/get a ride in it if it is out this weekend!
            DelSlow;312368 wrote:
            Is that a Snow kit?
            na, coolingmist stuff
            lol if only you knew...... I had an Oring blow out of one of my injectors when i was beating on it....
            smelt gas, opened the hood and there was a garden hose of gas under the hood. I don't know how it didn't go
            no chances now, lol
            na man, going to fargo
            not worth it for how strict they will be on a cage at BIR
            though would be a blast down there for sure, i am jealous of all you guys going, haha
              booooooooo
                May be a retarded question but, does that meth injection nozzle have any problems being so close to the BOV? or directly across from it? You would think when it opens, you would be releasing quite a bit of meth/water.
                  anytime the bov will be open the meth shouldnt be spraying iirc
                    Well what is this kits method of activating the solenoid?
                      ok so I didn't get to go the track the other weekend like i had planned on because the fuckers didn't get my windshield done, so that pist me off
                      so hopefully get there for the next street legal
                      anyway, just got my boost controller on. It is a hallman, and paid a little extra for the ceramic ball and extra spring
                      I didn't think the car could spool faster but i can definitely tell it does with the addition of just the BC
                      Bumped the car to 10psi now, honestly can't believe how much power these motors pick up on every pound of boost, it is nuts
                      as always, i like it nice and simple
                      and some will probably hate on me for this but whatever
                      my aluminum hood had a nice dent in it.... so i got rid of it.... and helped evacuate air in the process (thanks parker, haha)
                      FYI this picture does not lie....
                      with tape strips hanging off the edge of the vents you can very easily tell that there is a good volume and velocity of air coming up and out the vents when you are at speed
                      it always makes me LOL when people jack the back of the hood up and think that is going to help anything.....
                      and it gives the gawkers an idea what is under the hood, haha
                      needs some actual paint now
                        Fucking intercool that thing already.......
                          why? I have my big nozzle now, and my IAT's run at or below ambient air temps with the meth injection
                          I spose i should get a screen shot of a log so you believe me
                            aliengotpsi
                            do a 1st ------> 4th gear pull , what are your intake temps after that on a day its 85 degrees out.
                            Kevin Smith
                            Straightlinedetailing.com
                            • beachbum_jonB Offline
                              beachbum_jon
                              what is up with your front bumper?
                              -John Adams, 1735-1826-
                                Hmm...looks like the hole is about as big as an IC....hmmm I wonder??
                                  beachbum_jon
                                  hmm...that is what i was thinking at first, then i remembered that he going the water meth route vs. IC
                                  Oh and zac, what is the fitting just before the inlet of the compressor for?
                                    And then you remembered he used to have a GT42/13B setup...fail.
                                      for a pre turbo injection nozzle
                                      s
                                      i was in the fargo the last couple days, i will do a log with a screen shot
                                      and i have 3 gears...
                                        ok did a log this afternoon
                                        i guess i lied a bit, it gets 25-30* above ambient
                                        not to worried though because it is running very strong like it is.... i am on E30 with a 10.3:1 CR motor and some decent timing as you can see without any problems
                                        for the HP level it is at i should probably be running two 8 ghp nozzles not just one, but it runs really well right now so
                                        if you look at the log times from the beginning to the end you will see it took right at 7 seconds for that pull... i rolled into it a little bit so i didn't spin. And i didn't top 3rd out because that is too sketchy on the my road. The 2>3 shift puts you right in the 95-98mph area
                                        Boost is just a PID and that is why it is sort of unstable, if you look at the MAP you can see how stable the boost actually is
                                        oh and i heart HPT
                                          and yeah, the 65lb injectors are mostly done there
                                          no injection gets me 180* or a little better on the IAT's
                                          i have the tune setup to pull alot of timing if the IAT's go up so it should be fairly safe, and i have a pressure gauge in the car in the meth line so i can see that additionally
