  4. New Stuff
New Stuff
461 Posts 56 Posters 72.2k Views
    why? I have my big nozzle now, and my IAT's run at or below ambient air temps with the meth injection
    I spose i should get a screen shot of a log so you believe me
      aliengotpsi
      do a 1st ------> 4th gear pull , what are your intake temps after that on a day its 85 degrees out.
      Kevin Smith
      Straightlinedetailing.com
      • beachbum_jonB Offline
        beachbum_jon
        what is up with your front bumper?
        -John Adams, 1735-1826-
          Hmm...looks like the hole is about as big as an IC....hmmm I wonder??
            beachbum_jon
            hmm...that is what i was thinking at first, then i remembered that he going the water meth route vs. IC
            Oh and zac, what is the fitting just before the inlet of the compressor for?
              And then you remembered he used to have a GT42/13B setup...fail.
                for a pre turbo injection nozzle
                s
                i was in the fargo the last couple days, i will do a log with a screen shot
                and i have 3 gears...
                  ok did a log this afternoon
                  i guess i lied a bit, it gets 25-30* above ambient
                  not to worried though because it is running very strong like it is.... i am on E30 with a 10.3:1 CR motor and some decent timing as you can see without any problems
                  for the HP level it is at i should probably be running two 8 ghp nozzles not just one, but it runs really well right now so
                  if you look at the log times from the beginning to the end you will see it took right at 7 seconds for that pull... i rolled into it a little bit so i didn't spin. And i didn't top 3rd out because that is too sketchy on the my road. The 2>3 shift puts you right in the 95-98mph area
                  Boost is just a PID and that is why it is sort of unstable, if you look at the MAP you can see how stable the boost actually is
                  oh and i heart HPT
                    and yeah, the 65lb injectors are mostly done there
                    no injection gets me 180* or a little better on the IAT's
                    i have the tune setup to pull alot of timing if the IAT's go up so it should be fairly safe, and i have a pressure gauge in the car in the meth line so i can see that additionally
                      that is gay, how come they don't get bigger when you click on the pic? can't see any of the numbers
                        quadruple post FTL
                          i think you should buy bigger injectors and an intercooler. 😉
                            some could say the same to you 😉
                              you're right.
                              how about this...
                              i'll buy bigger injectors and an intercooler if zac does too. 🙂
                                integra_gsr98;314069 wrote:
                                you're right.
                                how about this...
                                <u>i'll buy bigger injectors and an intercooler if zac does too</u>. 🙂
                                K deal.....
                                First, just installed some new ID1000's...... going to switch to E85 and maybe bump the boost up till the tranny or converter goes
                                I have a date on the dyno Friday with Andy
                                got some new 26x9 slicks..... ordered some matching 15" FNs but they are backordered till Dec. so i canceled that......... so now i guess i will mount them on my OE 6" wheels. Hopefully i do not end up in the wall
                                and last, a project for the winter, probably my best buy ever on Ebay. It is Wheel to Wheels inventory (the rotax supercharger people)...... Garrett core and no china craps welds.... $40..... they didn't to a good job listing there stuff
                                  that intercooler for that price is bananas. sweet mang!
                                    so wheres GSR on his end of the bet?
                                      Coming soon. I've got other parts to buy first.
                                        dyno and track vid
                                        disappointing at the dyno, I had planed to up the boost to 12-15psi, but with my 4psi WG springs i couldn't get more than 8psi.... and my $2 summit converter is not so good and coupling, ha
                                        FYI, Andy is the man, best money i have ever spent on the car
                                        [http://www.youtube.com/watch?v=q1yumXathAw#]8psi](http://www.youtube.com/watch?v=q1yumXathAw#]8psi)
                                        then to the track..... I didn't think i would spin on slicks but did
                                        [http://www.youtube.com/watch?v=rOHGG1kvBIc&playnext=1&videos=PRHJyJIzJKM&feature=mfu_in_order#]10.37](http://www.youtube.com/watch?v=rOHGG1kvBIc&playnext=1&videos=PRHJyJIzJKM&feature=mfu_in_order#]10.37)
                                          Cant see at work 😞
