  4. where to get injectors tested
8 Posts 7 Posters 995 Views
  • fdfreakF Offline
    fdfreakF Offline
    fdfreak
    I think one of my primary injectors is stuck open. just curious where to get them tested/repaired/cleaned.
    12.645@118mph 12.6psi
      talk to faber... i think his dad's work does it...
        Just do what we did back in the day, pull the fuel rail off, put the whole thing into a bucket, and see how it sprays etc. I think theres something you can soak the tips in that cleans it up...maybe like injector cleaner?
          I can probably help you out on the testing of the injector.
          If you have a multi meter, I would start by taking an ohm meter across the pins on the injector.
          • tntmstrT Offline
            tntmstrT Offline
            tntmstr
            If you want an indepth analysis of 1 or more injectors, I'd strongly recommend: http://www.witchhunter.com/
            Jason Christopherson
            Store Manager
            Tintmasters
            Fargo, ND (701)239-TINT
            www.tintmasters.net
              TurboGTU
              x2, I've heard great things about them from everyone on rx7club. I'm sending mine out to get cleaned and such over the winter.
              2006 Mazda 6s Grand Sport
              • fdfreakF Offline
                fdfreakF Offline
                fdfreak
                Just found this. cheap and probably wont take more than an hour to build including running to the store. Its not too technical nor will it give me in depth analysis however it will let me know if the injector is stuck or not.
                http://www.youtube.com/watch?v=VFJlTfHyrUk
                  I also support the choice of witchhunter.com; low prices and quick turn-around.
