where to get injectors tested
fdfreak;314884 wrote:
I think one of my primary injectors is stuck open. just curious where to get them tested/repaired/cleaned.Just do what we did back in the day, pull the fuel rail off, put the whole thing into a bucket, and see how it sprays etc. I think theres something you can soak the tips in that cleans it up...maybe like injector cleaner?
If you want an indepth analysis of 1 or more injectors, I'd strongly recommend: http://www.witchhunter.com/
tntmstr;314930 wrote:
If you want an indepth analysis of 1 or more injectors, I'd strongly recommend: http://www.witchhunter.com/x2, I've heard great things about them from everyone on rx7club. I'm sending mine out to get cleaned and such over the winter.
Just found this. cheap and probably wont take more than an hour to build including running to the store. Its not too technical nor will it give me in depth analysis however it will let me know if the injector is stuck or not.
I also support the choice of witchhunter.com; low prices and quick turn-around.
