  4. Removing paint from concerte?
13 Posts 7 Posters 1.6k Views
  • beachbum_jonB Offline
    beachbum_jon
    So a can of VHT chassis paint got ran over on my driveway awhile back, but I will be moving out the end of this month and I kind of forgot about it being there. Tonight I tried using aircraft brand paint thinner, with little luck. Anyone have any other suggestions? I thought about renting a pressure washer, but I would like some more insight on the subject. If needed I will take a picture tomorrow in the day light if you need to see the amount of area I am dealing with.
    Thanks, Jon
    -John Adams, 1735-1826-
      Lots of elbow grease.
        rent a gas powered pressure washer, you wont even need to get any chemicals. otherwise, diesel fuel or kerosene works good.
          Sand blaster... done.
            Bah, just put some opaque sealant down. Cover the stain AND improve the lifespan!
            • svxALS Offline
              svxALS Offline
              svxAL
              jackhammer...
              94 Subaru SVX FWD
              subaru-svx.net
              1999 silverado
                beachbum_jon
                Thanks for the very constructive comments, something fargostreet is famous for. I had some luck with Lift off Graffiti remover. going to go and buy a gallon tomorrow. I did look into just buying a powerwasher, but tried this other route first. Thanks.
                  this^
                    I was serious about the sandblaster....
                      beachbum_jon
                      zbrown;315523 wrote:
                      this^
                      If I owned the house, I would spend the extra money on doing that. But being my lease is up the end of this month, I dont see the need.
                      I was talking more so about the "jackhammer" and the "lots of elbow grease" comments. I have heard about the sand blaster, just didnt know how well that would go over with the HOA, then again I could just blame it on the dust storm.
                        actually, go get some Zip Strip jelly in the black can
                        put some of that stuff on for awhile and see what happens, that shit usually makes stuff melt instantly
                        not sure if it will discolor the concrete or not
                          How much is there? You could get after it with a wire brush if it is small enough.
                            beachbum_jon
                            its about a 6ft by 10ft area, with some random splatter around that
