  4. Removing paint from concerte?
13 Posts 7 Posters 1.7k Views
  • JoelJ
    JoelJ
    rent a gas powered pressure washer, you wont even need to get any chemicals. otherwise, diesel fuel or kerosene works good.
    • ParkerP
      ParkerP
      Sand blaster... done.
      BlueSRT0483;244555 wrote:
      Trafik Jamz;260984 wrote:
      You are right Parker.
      • O
        O
        Bah, just put some opaque sealant down. Cover the stain AND improve the lifespan!
        • svxALS
          svxALS
          svxAL
          jackhammer...
          94 Subaru SVX FWD
          subaru-svx.net
          1999 silverado
          • beachbum_jonB
            beachbum_jonB
            beachbum_jon
            Thanks for the very constructive comments, something fargostreet is famous for. I had some luck with Lift off Graffiti remover. going to go and buy a gallon tomorrow. I did look into just buying a powerwasher, but tried this other route first. Thanks.
            -John Adams, 1735-1826-
            • zbrownZ
              zbrownZ
              this^
              • ParkerP
                ParkerP
                I was serious about the sandblaster....
                • beachbum_jonB
                  beachbum_jonB
                  beachbum_jon
                  zbrown;315523 wrote:
                  this^
                  If I owned the house, I would spend the extra money on doing that. But being my lease is up the end of this month, I dont see the need.
                  I was talking more so about the "jackhammer" and the "lots of elbow grease" comments. I have heard about the sand blaster, just didnt know how well that would go over with the HOA, then again I could just blame it on the dust storm.
                  • zbrownZ
                    zbrownZ
                    actually, go get some Zip Strip jelly in the black can
                    put some of that stuff on for awhile and see what happens, that shit usually makes stuff melt instantly
                    not sure if it will discolor the concrete or not
                    • MisterCMKM
                      MisterCMKM
                      How much is there? You could get after it with a wire brush if it is small enough.
                      thrash;315544 wrote:
                      Ford is back :)
                      • beachbum_jonB
                        beachbum_jonB
                        beachbum_jon
                        its about a 6ft by 10ft area, with some random splatter around that
