  4. car surging from 1000 to 1500 rpms
13 Posts 9 Posters 963 Views
    Bigger TB does not necessarily mean more power (this would be one of those cases). You are wrecking that motor, it will never be fast, so you might as well keep the awesome gas milage.
    That being said, ill take vacuum leak for $400 Alex.
      68mm t-body on vx, LOL
      • blackcherryTSiB Offline
        blackcherryTSi
        ecu... swap with another... will solve the problem
        1995 Honda Civic
        • gsrEKG Offline
          gsrEKG Offline
          gsrEK
          Hmm really? honda guru
          2009 Yamaha Zuma 125, gas HOG
          2008 Honda Fit daily
          A s2k
          1991 Honda civic DX Mint SOLD
          1988 Mitsubishi Mighty max
            lol sure
            • untitledfolderU Offline
              untitledfolder
              Vacuum leak, bad IACV, wrong plugs on sensors. It could be multiple things. Try the easy stuff first like taking off the IACV and cleaning it with brake cleaner, check and make sure you don't have any ports that are left open and aren't supposed to be.
              > ichibankilla;213613 wrote:
              2000 Honda Civic CX LS/Vtec
              http://www.clubredline.net
              • 95_gsr_swap9 Offline
                95_gsr_swap
                its going back to stock tonight. i just wanted to get rid of the egr valve and go to a normal throttle body ,but its gonna be a pain and not worth it so thanks for the info
                92 Honda Civic VX 1.5l vtec-e - SOLD
                86 Toyota Corolla - Project
                B18C1 Boost Project Soon To Be Done Once Home - SOLD
                92 civic coupe b18b swap
                  blackcherryTSi
                  DelSlow;315668 wrote:
                  lol sure
                  laugh all you want... its has to do with a burnt out piece inside. ive rode in the car, exact same thing happened with my rhd... swapped ecus and TA DA! all gone
                  1995 Honda Civic
                    95_gsr_swap
                    ok bryant if thats the case wut do i do with the vacuum lines id like to run the si manifold and throttle body so let me know if u have any ideas
                      blackcherryTSi
                      i can stop by and tinker with it any time this week if you want just hit me up
                      1995 Honda Civic
