  4. car surging from 1000 to 1500 rpms
13 Posts 9 Posters 963 Views
    periods are your friend
    just saying
      just saying
      What exactly does you and your sick choice of fetish have to do with this thread?
        Bigger TB does not necessarily mean more power (this would be one of those cases). You are wrecking that motor, it will never be fast, so you might as well keep the awesome gas milage.
        That being said, ill take vacuum leak for $400 Alex.
          68mm t-body on vx, LOL
          • blackcherryTSiB Offline
            blackcherryTSi
            ecu... swap with another... will solve the problem
            1995 Honda Civic
            • gsrEKG Offline
              gsrEKG Offline
              gsrEK
              Hmm really? honda guru
              2009 Yamaha Zuma 125, gas HOG
              2008 Honda Fit daily
              A s2k
              1991 Honda civic DX Mint SOLD
              1988 Mitsubishi Mighty max
                lol sure
                • untitledfolderU Offline
                  untitledfolder
                  Vacuum leak, bad IACV, wrong plugs on sensors. It could be multiple things. Try the easy stuff first like taking off the IACV and cleaning it with brake cleaner, check and make sure you don't have any ports that are left open and aren't supposed to be.
                  > ichibankilla;213613 wrote:
                  2000 Honda Civic CX LS/Vtec
                  http://www.clubredline.net
                  • 95_gsr_swap9 Offline
                    95_gsr_swap
                    its going back to stock tonight. i just wanted to get rid of the egr valve and go to a normal throttle body ,but its gonna be a pain and not worth it so thanks for the info
                    92 Honda Civic VX 1.5l vtec-e - SOLD
                    86 Toyota Corolla - Project
                    B18C1 Boost Project Soon To Be Done Once Home - SOLD
                    92 civic coupe b18b swap
                      blackcherryTSi
                      DelSlow;315668 wrote:
                      lol sure
                      laugh all you want... its has to do with a burnt out piece inside. ive rode in the car, exact same thing happened with my rhd... swapped ecus and TA DA! all gone
                      1995 Honda Civic
                        95_gsr_swap
                        ok bryant if thats the case wut do i do with the vacuum lines id like to run the si manifold and throttle body so let me know if u have any ideas
                          blackcherryTSi
                          i can stop by and tinker with it any time this week if you want just hit me up
                          1995 Honda Civic
