  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • JoelJ
    JoelJ
    so wheres GSR on his end of the bet?
    • integra_gsr98I
      integra_gsr98I
      Coming soon. I've got other parts to buy first.
      • zbrownZ
        zbrownZ
        dyno and track vid
        disappointing at the dyno, I had planed to up the boost to 12-15psi, but with my 4psi WG springs i couldn't get more than 8psi.... and my $2 summit converter is not so good and coupling, ha
        FYI, Andy is the man, best money i have ever spent on the car
        [http://www.youtube.com/watch?v=q1yumXathAw#]8psi](http://www.youtube.com/watch?v=q1yumXathAw#]8psi)
        then to the track..... I didn't think i would spin on slicks but did
        [http://www.youtube.com/watch?v=rOHGG1kvBIc&playnext=1&videos=PRHJyJIzJKM&feature=mfu_in_order#]10.37](http://www.youtube.com/watch?v=rOHGG1kvBIc&playnext=1&videos=PRHJyJIzJKM&feature=mfu_in_order#]10.37)
        • SPANISH-RICES
          SPANISH-RICES
          Cant see at work 😞
          • DaveHD
            DaveHD
            Was that on a transbrake?
            • zbrownZ
              zbrownZ
              no, just foot braking into about 3psi..... I can footbrake to nearly full boost and still hold it on the line, but will blow the tires off
              sucks cuz at strugis leaving on 1psi and just my 17" DRs i could pull a 1.54.... best at sabin was a 1.51 spinning badly with the slicks..... my 10.3 was only a 1.65
              wish i could run at a prepped BIR event just once, I know it would leave hard, a 1.5 seems super docile with this setup..... i remember a 1.6 with the rotary and manual seemed like i was gonna pull a wheel it was so violent
              • kylushK
                kylushK
                kylush
                What were the dyno numbers?
                1998 Z28 Camaro
                • GrrG
                  GrrG
                  470whp with 28% converter slip. Slipping converters dont dyno, so in a manual car that would likely be around 620whp
                  • bonestock_442B
                    bonestock_442B
                    bonestock_442
                    Awesome car!
                    • zbrownZ
                      zbrownZ
                      bonestock_442;316555 wrote:
                      Awesome car!
                      Thanks!... get the 475 done on your LS!
                      yeah 470whp on 8psi
                      I don't expect it to dyno much with the auto, care more about track times
                      though a decent converter wouldn't hurt on the dyno or track
                      i am working on a deal for a built rossler PG and a UCC converter, so that should help
                      • kylushK
                        kylushK
                        kylush
                        Yeah, as long as it's fast thats what counts. I was just curious what it made, overlooked the part about the converter slipping
                        1998 Z28 Camaro
                        • zbrownZ
                          zbrownZ
                          Well some of my new parts are showing up
                          I had Lonnie at PTC spec and build me a converter..... super excited to get an actual good converter infront of a new transmission setup to see how it works without massive slip!
                          Lonnie was super nice and helpful too, very satisfied
                          it was 5 days from when i called till when i received! and it has the ls1 pilot and pattern so i do not need to use any sort of adapter anymore
                          • zbrownZ
                            zbrownZ
                            So i picked up some like new complete Caddy LSA heads to try for cheap
                            I had planned on sending these off to either Lingfelter or WCCH for a port job
                            but the casting and finish on these is MUCH nicer compared my regular L92's..... so i may just do springs and bolt them down instead
                            The LS9/LSA heads differ from the normal ls3/l92 heads in these ways
                            different, better aluminum
                            better "rotocast" casting method
                            swirl fin in the intake port (you can see it in the left corner of the intake runner in my one pic)
                            some say thicker deck
                            difference from the LSA heads and the LS9 heads is that the LS9 uses larger headbolts and different valves (Ti)
                            • zbrownZ
                              zbrownZ
                              oh and look at the effects of E85 and meth injection.......
                              looks like almost new in there!
                              • funky_monkey58F
                                funky_monkey58F
                                funky_monkey58
                                Dude you should epoxy that floor, you will love it.
                                • SlowicaS
                                  SlowicaS
                                  Slowica
                                  very nice and that is impressive for how clean it still looks.
                                  • SlIcK wIlLieS
                                    SlIcK wIlLieS
                                    SlIcK wIlLie
                                    Z you still messin w/ 7`s?
                                    • zbrownZ
                                      zbrownZ
                                      oh yeah what is up?
                                      • zbrownZ
                                        zbrownZ
                                        Worked out well that i got home from nice hawaii to cold home yesterday...... but I had a present waiting so it made the transition better!
                                        In the end i decided to pick up a new set of done up LSA heads from Richard at WCCH...... SS valves...... dual springs..... 350+/240+ flow #s... .. large 75cc chambers
                                        Richard was great, very very helpful and always available to talk. So a +1 for him
                                        and their work speaks for themselves as why i went to them
                                        So i have a like new set of stock LSA's here if anyone would be interested for cheap
                                        CR will be at 9.9 now instead of ~10.6 like it was on the stock chamber L92's....... got to love E85.... even with the previous high CR and no IC, no det problems
                                        • 63vette6
                                          63vette6
                                          63vette
                                          dubbsy;256235 wrote:
                                          no rotary no care...
                                          Watch "Rotary Mayor Meets Lenco Jim".
                                          http://dragraceplace.com/#vid
