New Stuff
capitlj;317943 wrote:
So intercooler + lower static compression = moar boost?should make alot more power at the same boost, or atleast put it to the ground with the good converter now
but yeah will be able to run as much boost as that little turbo will support anyway
.Got my trans from Josh at Kentucky Turbo.... he had it built for his 1000hp build but decided to go 4l80 instead
it is fresh with good stuff and a brake, I shouldn't have to worry about breaking it anytime soon
the ratio of low gear should really help me with traction, and let the engine load up better in my light car
nice and light too
zbrown;318186 wrote:
should make alot more power at the same boost, or atleast put it to the ground with the good converter nowbut yeah will be able to run as much boost as that little turbo will support anyway
nice and light too
Need more info on the glide. ????
the glide is
RMVB
pro tree brake
turbo input
1.76 straight cut with stock carrier.
8 clutch high gear
Ok now i realize 98% of you guys will hate this, really i do, so it is alright to bash
i just get carried away when i start messing with aluminum because it is so fun, and i had a big hole already
I need to do some trimming yet, and i will probably paint it all black
k got my supplies for plumbing the coolant, assholes sent me red/blue instead of black like i ordered. It is Earl's fittings and pro-lite hose
If i did it again i would have gone -16, i didn't realize how big -20 actually was, and -16 fittings/hose is alot cheaper/abundant
just the straight hose ends are over 50 bucks a piece for that size
also adding a thermostat, it is an inline meziere housing. Doing this just to give the car a chance to warm up quicker, and to slow the coolant flow down some for better heat transfer in the radiator
.and yes i did cut out my fenders, I plan to add a dump right off the turbo and out the front fender with an electric cutout, and this gives me the room to do it
and kind of what the mega bug catcher looks like, not done yet though..... I love dust
