  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • zbrownZ
    zbrownZ
    Might get around to a cage
    • capitljC
      capitljC
      capitlj
      Looking good as usual mister Brown.
      Mitch Hedberg wrote:
      2004 Impala LS 3.8
      • kylushK
        kylushK
        kylush
        Looks sick, those heads look really nice!
        1998 Z28 Camaro
        • zbrownZ
          zbrownZ
          thanks
          you should do a truck manifold setup on yours?
          • kylushK
            kylushK
            kylush
            haha yes I should... Finally done with school and got a job in Watertown so hopefully I'll have some money and time to throw at it in the next couple years. Got a dyno and a very good tuner nearby from what I hear
            1998 Z28 Camaro
            • zbrownZ
              zbrownZ
              Yeah andy is good shit
              • capitljC
                capitljC
                capitlj
                So intercooler + lower static compression = moar boost?
                2004 Impala LS 3.8
                • zbrownZ
                  zbrownZ
                  should make alot more power at the same boost, or atleast put it to the ground with the good converter now
                  but yeah will be able to run as much boost as that little turbo will support anyway
                  Got my trans from Josh at Kentucky Turbo.... he had it built for his 1000hp build but decided to go 4l80 instead
                  it is fresh with good stuff and a brake, I shouldn't have to worry about breaking it anytime soon
                  the ratio of low gear should really help me with traction, and let the engine load up better in my light car
                  nice and light too 🙂
                  • zbrownZ
                    zbrownZ
                    and since i am an idiot that didn't post it up, it is a powerglide
                    • z31Z
                      z31Z
                      z31
                      Need more info on the glide. ????
                      • zbrownZ
                        zbrownZ
                        the glide is
                        RMVB
                        pro tree brake
                        turbo input
                        1.76 straight cut with stock carrier.
                        8 clutch high gear
                        Ok now i realize 98% of you guys will hate this, really i do, so it is alright to bash 😉
                        i just get carried away when i start messing with aluminum because it is so fun, and i had a big hole already
                        I need to do some trimming yet, and i will probably paint it all black
                        • DelSlowD
                          DelSlowD
                          Your tabs are expired.
                          • zbrownZ
                            zbrownZ
                            k got my supplies for plumbing the coolant, assholes sent me red/blue instead of black like i ordered. It is Earl's fittings and pro-lite hose
                            If i did it again i would have gone -16, i didn't realize how big -20 actually was, and -16 fittings/hose is alot cheaper/abundant
                            just the straight hose ends are over 50 bucks a piece for that size
                            also adding a thermostat, it is an inline meziere housing. Doing this just to give the car a chance to warm up quicker, and to slow the coolant flow down some for better heat transfer in the radiator
                            and yes i did cut out my fenders, I plan to add a dump right off the turbo and out the front fender with an electric cutout, and this gives me the room to do it
                            and kind of what the mega bug catcher looks like, not done yet though..... I love dust
                            • zbrownZ
                              zbrownZ
                              • FG2F
                                FG2F
                                FG2
                                looks really good man! I am excited to see it out this summer....but I also agree....stop making it go faster, and cage it!
                                • zbrownZ
                                  zbrownZ
                                  ha, thanks Dad!
                                  and because you say so, i bought a 8pt DOM cage for it this morning! haha, really i did
                                  • zbrownZ
                                    zbrownZ
                                    start
                                    finish
                                    • funky_monkey58F
                                      funky_monkey58F
                                      funky_monkey58
                                      Ooooooh pretty.
                                      • dubbsyD
                                        dubbsyD
                                        • dubbsyD
                                          dubbsyD
                                          zbrown;318579 wrote:
                                          ha, thanks Dad!
                                          only 8?
