  4. FS: AMS Small Battery Kit for Evo $200
2 Posts 1 Posters 948 Views
  • B
    B
    Used for about a year. Needed to go to a bigger battery as I drive my car year round and it will often sit outside. This saves wait and clears room for aftermarket intercooler piping.
    Good condition $200 - Will need to purchase your own battery posts.
    The information as taken directly from AMS website:
    The AMS EVO VII/VIII/IX Small Battery Kit replaces your heavy factory battery with a lightweight race battery. This kit significantly reduces weight and frees up space for our free flowing upper intercooler pipe. Our high quality components guarantee long life and the battery itself will have no trouble starting your vehicle in harsh conditions. The tray included is TIG welded by hand using high grade aluminum and the battery is topped off with a CNC'd AMS tie down plate. All factory mounting points are used making installation simple. While it can be used in cars with mild stereo upgrades it’s not ideal for high output stereo systems.
    Features
    Effortless install uses factory mounting points
    Entire kit weighs 15lbs. lowering overall weight
    High quality, long life, car starts every time
    Custom AMS battery tie down plate
    Kit Includes
    AMS small battery
    Aluminum AMS battery tie down plate
    Zinc plated tie down hooks to prevent rusting over time
    Nylon washers to keep the hardware from scratching the anodized tie down plate
    Durable non slip battery pad to keep the battery in place and protected
    Wing nuts for an easy install and removal
    Adjustable for use with almost all small batteries
    Specifications
    680 cranking amps
    Short circuit current over 1800A
    25 minute reserve capacity with 25amp load
    Length 7 1/16"
    Width 2 15/16"
    Height 7 3/16"
    Weight 14.6 lbs
    Applications
    Mitsubishi Evolution 7, 8, 9
    GSR, MR, RS and SE
    • B
      B
      no one needs something like this? I'd like to clear it out of the garage!
