"Cornfed Killer" Build
Im sorry but what is the point of "temporary spray paint" until real paint? How do you plan on making legit paint stick with one coat of shitty black and another coat of shitty white on top of it? Looks like it started as teal at one point.
and im having a hard time believing its an "EX" when it has no passenger mirror and no a/c switch. regardless, good luck with the build
SPANISH-RICE;319281 wrote:
Im sorry but what is the point of "temporary spray paint" until real paint? How do you plan on making legit paint stick with one coat of shitty black and another coat of shitty white on top of it? Looks like it started as teal at one point.and im having a hard time believing its an "EX" when it has no passenger mirror and no a/c switch. regardless, good luck with the build
The paint it to make it look halfway decent from the shit black/green that it was... And if you would have read, I'm sanding it all down to make it all clean and smooth when it gets painted so you don't have to worry about my spray paint job anymore... ALSO the dash was swapped because the old one was all painted and had holes drilled for gauges in it. It's a true ex, mirror was removed because it was broken and had a spare block off plate
If you still aren't satisfied with that then come on over and take a gander at the vin codes and run then to make sure.... Like I did
Rexwagon;319295 wrote:
so since its a legit EX does that give it more HP?wtf
capitlj;319306 wrote:
Yeah why would that matter?a real EX adds 10hp off the bat and grows exponentially throughout the build... common fact
gsrEK;319319 wrote:
shits hella scatttythanks for the kind words! i know im lacking pie cuts but that will come later
meh just making an observation theres no need to get so defensive. but when checking the vin did you manage to figure out what year it is? 94 or 95?. but either way this got out of hand. if you prefer to put a coat of shitty paint under "legit" paint, thats your deal.
I saw you driving it didnt sound to bad, needs paint though
LOL
Just got back from the dyno 349hp 326tq at 23psi... had room to push it more but didnt wanna risk it!
Weak.....
