  4. Turboed 4g63
Turboed 4g63
51 Posts 11 Posters 2.1k Views
    MrScary wrote:
    I know you can't really turn up the boost much. But could you retard the ignition to make it work?
    Are you talking about turboing an originally N/A 4g63? If so, I'm not sure about your question. If your talking about a turbo DSM (ev0, Eclipse,talon,lazer,gvr4) than Your an Idiot. Look around this site. Over 50 percent of this site owns DSM's and I'm sure you can ask 92nbTsi, 99slowgsx, Jim, PSI2HI or practically anyone else about running high boost with a 4g63. What was it last year Kevin? 32 lb.s on stock internals?
      MrScary wrote:
      If you put a turbo on a NA 4G63 you can only turn the boost to like 8 psi. Would retarded the ignition let you turn up the boost more. Sorry I didn't make it as specific
      youd have to ask psi2hi on that one...i'd say you could probably run around 12
        www.dsmtuners.com has a good forum on na 4g63........
        • M Offline
          M Offline
          MrScary
          I've been checkin out dsmtuners but I can't register because I only have free email addresses
            then just don't register.....I haven't registered and I can still access the forums.
            ps- dsmtuners does recommend not much more that 8lbs on an N/T 4g63
              I thought the number for the motor in the N/A DSM's was a 420A?
                From like 94 or so on........90,91,92 are 4g63 for sure, nut sure about 93.
                  it's all how you go about tuning the na-t. if you just use a fmu, then you'll be limited to very little boost, but if you get a better means of tuning (ie piggyback) then you might be able to run a bit more. as nick thompson will tell you, it's not how much boost you run, but how much air you're pushing in, get a 57trim and run 5psi 😉 you won't be disappointed
                    all non 1.8liter N/A 1G dsms are 4G63s...95+ N/As are 420a's=poopy
                      If you wanna do it right buy a turbo ECU and wire in a knock sensor. Thatd the big downfall on the N/A there's no knock sensor. The knock sensor is the sole purpose on why DSM's can take all the abuse and high boost w/o instantly blowing up. The NA is 9:1 CR and the ringlands are moved furher up on the piston so your gonna have to be a lot more careful w/ the tuning but it will make more power then the standard turbo DSM on the same boost.
                      • W Offline
                        W Offline
                        Wizard
                        I would have to say that the pistons are the big downfall with the NA motor getting turbo'd. You can build any motor without a knock sensor. And even tune without it. But even with a knock sensor in a NA motor, you are still limited to what the pistons can handle.
                        Wiz
                        1992 GVR4 598/1000 Nile Black
                        1992 Tsi AWD
                        1982 Datsun KC 4x4
                        1990 Laser 2.0 AT NT
                        1994 ES 2.0L NT 5-spd
                          The knock sensor is the whole survival of a DSM, point said and done. 9:1 is not a crazy high compression ratio. The pistons will take the boost no problem. But w/o either A) A knock sensor, or B) A piggyback tuning device and some logging it will not work. W/ either or those or even both would be nice the motor will go strong and make more power than your standard turbo DSM.
                            that's what i was implying, that without any form of accurate logging or fuel management that's more involved than an fmu, the engine would be just like any other piece of poo with a turbo
                            • M Offline
                              M Offline
                              MrScary
                              So it would involve the turbo all components and a Turbo ECU? And what about partially rebuilding the engine?ie new pistons, rods, maybe a cam that will account for the turbo
                                the only difference in the head of a NT 4g63, are the cams... you can find turbo cams cheaply.
                                If you change the pistons, rods you'll basicaly have a 4g63T engine
                                  If you really want a turbo 4G63 that bad, just buy a TSi/GSX and save the hassle.
                                  • M Offline
                                    M Offline
                                    MrScary
                                    http://www.dsmtuners.com/parts/default.php?cPath=2_38&osCsid=386242d6ef1019e3f278e853bd4618f8
                                    Would one of these work and what about that stroker kit???
                                      all you need to turbo your car (cheaply) is the turbo manifold, turbo, intercooler and fuel control. with the dsm, you have access to the ecu, which is perhaps the most difficult thing to figure out with a lot of na-t cars. but with the new ecu, you'd still need fuel control (7.8:1 vs 9:1), so i think it would be easier to just get an afc (ecu piggyback) and play from there. a knock sensor would be a great idea... almost easier to just get a 4g63t. look around on dsmtuners, try to find a way to get an account on there so you can use the search function.
                                      • M Offline
                                        M Offline
                                        MrScary
                                        you know of any places that sell a ecu piggyback???
                                          or if you really want to turbo you n/a 4g63 i have 7 bolt turbo cams, rods, crank...pretty much everything from a turbo 7 bolt 4g63....the pistons are okay but they need new rings.
