  4. Turboed 4g63
Turboed 4g63
51 Posts 11 Posters 2.4k Views
    From like 94 or so on........90,91,92 are 4g63 for sure, nut sure about 93.
      it's all how you go about tuning the na-t. if you just use a fmu, then you'll be limited to very little boost, but if you get a better means of tuning (ie piggyback) then you might be able to run a bit more. as nick thompson will tell you, it's not how much boost you run, but how much air you're pushing in, get a 57trim and run 5psi 😉 you won't be disappointed
        all non 1.8liter N/A 1G dsms are 4G63s...95+ N/As are 420a's=poopy
          If you wanna do it right buy a turbo ECU and wire in a knock sensor. Thatd the big downfall on the N/A there's no knock sensor. The knock sensor is the sole purpose on why DSM's can take all the abuse and high boost w/o instantly blowing up. The NA is 9:1 CR and the ringlands are moved furher up on the piston so your gonna have to be a lot more careful w/ the tuning but it will make more power then the standard turbo DSM on the same boost.
          • W Offline
            W Offline
            Wizard
            I would have to say that the pistons are the big downfall with the NA motor getting turbo'd. You can build any motor without a knock sensor. And even tune without it. But even with a knock sensor in a NA motor, you are still limited to what the pistons can handle.
            Wiz
            1992 GVR4 598/1000 Nile Black
            1992 Tsi AWD
            1982 Datsun KC 4x4
            1990 Laser 2.0 AT NT
            1994 ES 2.0L NT 5-spd
              The knock sensor is the whole survival of a DSM, point said and done. 9:1 is not a crazy high compression ratio. The pistons will take the boost no problem. But w/o either A) A knock sensor, or B) A piggyback tuning device and some logging it will not work. W/ either or those or even both would be nice the motor will go strong and make more power than your standard turbo DSM.
                that's what i was implying, that without any form of accurate logging or fuel management that's more involved than an fmu, the engine would be just like any other piece of poo with a turbo
                • M Offline
                  M Offline
                  MrScary
                  So it would involve the turbo all components and a Turbo ECU? And what about partially rebuilding the engine?ie new pistons, rods, maybe a cam that will account for the turbo
                    the only difference in the head of a NT 4g63, are the cams... you can find turbo cams cheaply.
                    If you change the pistons, rods you'll basicaly have a 4g63T engine
                      If you really want a turbo 4G63 that bad, just buy a TSi/GSX and save the hassle.
                      • M Offline
                        M Offline
                        MrScary
                        http://www.dsmtuners.com/parts/default.php?cPath=2_38&osCsid=386242d6ef1019e3f278e853bd4618f8
                        Would one of these work and what about that stroker kit???
                          all you need to turbo your car (cheaply) is the turbo manifold, turbo, intercooler and fuel control. with the dsm, you have access to the ecu, which is perhaps the most difficult thing to figure out with a lot of na-t cars. but with the new ecu, you'd still need fuel control (7.8:1 vs 9:1), so i think it would be easier to just get an afc (ecu piggyback) and play from there. a knock sensor would be a great idea... almost easier to just get a 4g63t. look around on dsmtuners, try to find a way to get an account on there so you can use the search function.
                          • M Offline
                            M Offline
                            MrScary
                            you know of any places that sell a ecu piggyback???
                              or if you really want to turbo you n/a 4g63 i have 7 bolt turbo cams, rods, crank...pretty much everything from a turbo 7 bolt 4g63....the pistons are okay but they need new rings.
                                straightline specialties in fargo: http://www.straightlinespecialties.com
                                I'm gonna have to disagree with out there, its not really easier to get the entire 4G63 becuase it will be alot more expensive.
                                The best way to do it would be to get all of the needed parts: Turbo ECU, Knock sensor, turbo injectors (450cc not the auto ones), turbo, manifold, oil lines.
                                If your looking to actually make power, you'd want to look at getting different cams. The NT 9:1 pistons arent terrible, with correct tuning and that higher compression you can put out some good numbers.
                                Your going to also need a fuel pump if you plan on running any amount of boost.
                                Depending on what parts you can find used, it might be sort of costly to do right. There cheaper ways to do it, but if its just going to blow up whats the point?
                                Might want to look in to what you can get for the car, and see if you can find a nice AWD 1G... everythings pretty cheap these days
                                  Um...? I thought yours blew up?
                                  He's already got a 7 bolt block, the same rods as you have, and the 2G head is totally different so your parts wouldn't workin his. You cant re-use those pistons anyway...
                                    most of those are stand-alones, stay away from them.
                                    any place that sells import performance parts has piggyback systems, they are usually referred to by name (safc, for example).
                                    you should ignore the idea of a stroker engine for a long time, you're still learning about what it takes to build a turbo engine... gotta learn to walk before you can run the boston marathon
                                    EDIT: jim, i meant that it might be a little easier, not cheaper 😉 and i do not believe the ecu from any turbo dsm will work unaided, due to the compression difference. otherwise i believe we're both preaching nearly the same gospel, just in different languages 😄
                                    • M Offline
                                      M Offline
                                      MrScary
                                      Ok then right now I want to do intake and exhaust. Who makes an intake and a good exhaust: header, downpipe, cat-back
                                        To clear up confusion from earlier in this post:
                                        90-94 (1st Gen) Turbo Cars: 4G63T
                                        90-94 (1st Gen) Non Turbo: 4G63
                                        95-99 (2nd Gen) Non Turbo: Chrysler 420a
                                        95-99 (2nd Gen) Turbo: 4G63
                                          Don't waste your money, you won't notice any significant gains. You'll be hard pressed to find NA aftermarket for 4G63 becuase nobody bothers...
                                          Save your money for a turbo setup, or a turbo car if you want to modify a DSM its the only way
