New Stuff
24valvenotak;319234 wrote:
bs.ha it is truth
.new turbo showed up from FI
got a new Precision 7875 (78hpsh) uses the 75mm gt42's turbine compared to the 68mm F1-68 i had before in the TC
should still spool nice and fast but open it up quite a bit for power
was torn between a PT88 or the 78 GTS, but i still wanted some decent response so went with the GTS
Grr;319326 wrote:
weak sauce, should have gotten the comp 8079!
x2. -
PSiedTSi;319389 wrote:
Whats your old turbo or did you already sell it?yeah i already sold it, it was a turbonetics TC78
I am surprised none of the 2jz guys have tried them, seems they would work well with that engine, big compressor and smaller turbine
Grr;319326 wrote:
weak sauce, should have gotten the comp 8079!funky_monkey58;319439 wrote:
x2.i probably would have but didn't want to chance it not fitting, i am about positive the comp compressor cover for that turbo is bigger than the GTS
and i already had to do some work with a flap disk to get this one to fit without hitting
Nice! How do you like the aluminum Vband?
funky_monkey58;319711 wrote:
Nice! How do you like the aluminum Vband?DaveH;319710 wrote:
That turned out really nice, great work.Grr;319709 wrote:
wow that looks great, just as I expectedweshole;319708 wrote:
Very nice bro!!thanks guys
I really like the aluminum V-band, but the o-ring they sent was almost a cunt hair big
it was a bitch to make sure it was in there and seated correctly
got it all together and running
all i can say is that thing is going to be nasty now with that converter and transbrake
converter is tight but i can still light up the new turbo to full boost like nothing with the brake
muffler isn't hooked up yet, so that is why it is so loud
So who had balls of steel to stand in front and video?
there is only one guy that i know of. -
dubbsy;319736 wrote:
you're gonna need more tire.possibly haha
got the fans done
didn't quite have the depth to fit a taurus fan so i got a dual setup off of summit
worked out great, my core size is 24x16 and these where 23.5x16 with a little trimming on top
anyway, made this little deal and then it bolted to the radiator just right
