  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • funky_monkey58F
    funky_monkey58F
    funky_monkey58
    Woot for no more blowing off your radiator hoses!
    • 24valvenotak2
      24valvenotak2
      zbrown;319231 wrote:
      because i am lazy
      bs.
      63vette;288530 wrote:
      • ParkerP
        ParkerP
        Needs more cow bell.
        BlueSRT0483;244555 wrote:
        Trafik Jamz;260984 wrote:
        You are right Parker.
        • zbrownZ
          zbrownZ
          24valvenotak;319234 wrote:
          bs.
          ha it is truth
          new turbo showed up from FI
          got a new Precision 7875 (78hpsh) uses the 75mm gt42's turbine compared to the 68mm F1-68 i had before in the TC
          should still spool nice and fast but open it up quite a bit for power
          was torn between a PT88 or the 78 GTS, but i still wanted some decent response so went with the GTS
          • GrrG
            GrrG
            weak sauce, should have gotten the comp 8079!
            • PSiedTSiP
              PSiedTSiP
              Whats your old turbo or did you already sell it?
              spanish-rice;237125 wrote:
              • funky_monkey58F
                funky_monkey58F
                funky_monkey58
                x2.
                • zbrownZ
                  zbrownZ
                  yeah i already sold it, it was a turbonetics TC78
                  I am surprised none of the 2jz guys have tried them, seems they would work well with that engine, big compressor and smaller turbine
                  funky_monkey58;319439 wrote:
                  x2.
                  i probably would have but didn't want to chance it not fitting, i am about positive the comp compressor cover for that turbo is bigger than the GTS
                  and i already had to do some work with a flap disk to get this one to fit without hitting
                  • zbrownZ
                    zbrownZ
                    little bit of work and it fits, the compressor cover definitely a good bit larger than the TC
                    next up is IC plumbing
                    • zbrownZ
                      zbrownZ
                      Got the IC plumbing all done, really like how it turned out.
                      3" aluminum
                      • wesholeW
                        wesholeW
                        Very nice bro!!
                        • GrrG
                          GrrG
                          wow that looks great, just as I expected
                          • DaveHD
                            DaveHD
                            That turned out really nice, great work.
                            • funky_monkey58F
                              funky_monkey58F
                              funky_monkey58
                              Nice! How do you like the aluminum Vband?
                              • zbrownZ
                                zbrownZ
                                weshole;319708 wrote:
                                Very nice bro!!
                                thanks guys
                                I really like the aluminum V-band, but the o-ring they sent was almost a cunt hair big
                                it was a bitch to make sure it was in there and seated correctly
                                • zbrownZ
                                  zbrownZ
                                  got it all together and running
                                  all i can say is that thing is going to be nasty now with that converter and transbrake
                                  converter is tight but i can still light up the new turbo to full boost like nothing with the brake
                                  muffler isn't hooked up yet, so that is why it is so loud
                                  http://www.youtube.com/watch?v=q_7bD8ORT_w
                                  • funky_monkey58F
                                    funky_monkey58F
                                    funky_monkey58
                                    So who had balls of steel to stand in front and video?
                                    • G
                                      G
                                      Gutless
                                      Sounds mean. Sounds like a jet when it spools up. LS's are probably one of the better sounding engines out there. I think they are only second to a big block Olds or Buick.
                                      Are you using a stock ECU to control it or something like a megasquirt or FAST?
                                      Whats fuel injection?
                                      Stuck with buick V6's.
                                      81 Cutlass- Drawthrough turbo 6
                                      97 Firebird- FWD motor turned the right way, Supercharged 3800
                                      • S
                                        S
                                        squawsnatch
                                        there is only one guy that i know of.
                                        • dubbsyD
                                          dubbsyD
                                          you're gonna need more tire.
