  4. New Stuff
New Stuff
461 Posts 56 Posters 72.2k Views
  • FG2F Offline
    FG2F Offline
    FG2
    looks really good man! I am excited to see it out this summer....but I also agree....stop making it go faster, and cage it!
      ha, thanks Dad!
      and because you say so, i bought a 8pt DOM cage for it this morning! haha, really i did
        start
        finish
        • funky_monkey58F Offline
          funky_monkey58
          Ooooooh pretty.
          • dubbsyD Offline
            dubbsyD Offline
            • dubbsyD Offline
              dubbsyD Offline
              zbrown;318579 wrote:
              ha, thanks Dad!
              only 8?
                dubbsy;318583 wrote:
                only 8?
                yeah, i don't want a 10pt in there, maybe later but doubt it
                got the radiator and cooling plumbing done, really like the way it turned out
                heat cycled it a couple times now so i can retorque
                  8pt is only good to 10.0 and or 135mph. 10pt it and be done.
                    yeah i dont want to tear my dash apart and do the cross bar because i am lazy
                    was bored so i built a heat shield for the turbine housing out of some aluminum scraps
                    turned out better than i thought it would, looks nice
                    and yes i know the retainers go underneath not on top, lol
                      funky_monkey58
                      Woot for no more blowing off your radiator hoses!
                        zbrown;319231 wrote:
                        because i am lazy
                        bs.
                          Needs more cow bell.
                            24valvenotak;319234 wrote:
                            bs.
                            ha it is truth
                            new turbo showed up from FI
                            got a new Precision 7875 (78hpsh) uses the 75mm gt42's turbine compared to the 68mm F1-68 i had before in the TC
                            should still spool nice and fast but open it up quite a bit for power
                            was torn between a PT88 or the 78 GTS, but i still wanted some decent response so went with the GTS
                              weak sauce, should have gotten the comp 8079!
                                Whats your old turbo or did you already sell it?
                                  funky_monkey58
                                  x2.
                                    yeah i already sold it, it was a turbonetics TC78
                                    I am surprised none of the 2jz guys have tried them, seems they would work well with that engine, big compressor and smaller turbine
                                    funky_monkey58;319439 wrote:
                                    x2.
                                    i probably would have but didn't want to chance it not fitting, i am about positive the comp compressor cover for that turbo is bigger than the GTS
                                    and i already had to do some work with a flap disk to get this one to fit without hitting
                                      little bit of work and it fits, the compressor cover definitely a good bit larger than the TC
                                      next up is IC plumbing
                                        Got the IC plumbing all done, really like how it turned out.
                                        3" aluminum
                                          Very nice bro!!
