New Stuff
k got my supplies for plumbing the coolant, assholes sent me red/blue instead of black like i ordered. It is Earl's fittings and pro-lite hose
If i did it again i would have gone -16, i didn't realize how big -20 actually was, and -16 fittings/hose is alot cheaper/abundant
just the straight hose ends are over 50 bucks a piece for that size
also adding a thermostat, it is an inline meziere housing. Doing this just to give the car a chance to warm up quicker, and to slow the coolant flow down some for better heat transfer in the radiator
.and yes i did cut out my fenders, I plan to add a dump right off the turbo and out the front fender with an electric cutout, and this gives me the room to do it
and kind of what the mega bug catcher looks like, not done yet though..... I love dust
Ooooooh pretty.
PSI2HI;318924 wrote:
8pt is only good to 10.0 and or 135mph. 10pt it and be done.yeah i dont want to tear my dash apart and do the cross bar because i am lazy
was bored so i built a heat shield for the turbine housing out of some aluminum scraps
turned out better than i thought it would, looks nice
and yes i know the retainers go underneath not on top, lol
Woot for no more blowing off your radiator hoses!
zbrown;319231 wrote:
because i am lazybs.
24valvenotak;319234 wrote:
bs.ha it is truth
.new turbo showed up from FI
got a new Precision 7875 (78hpsh) uses the 75mm gt42's turbine compared to the 68mm F1-68 i had before in the TC
should still spool nice and fast but open it up quite a bit for power
was torn between a PT88 or the 78 GTS, but i still wanted some decent response so went with the GTS
Grr;319326 wrote:
weak sauce, should have gotten the comp 8079!
x2. -
PSiedTSi;319389 wrote:
Whats your old turbo or did you already sell it?yeah i already sold it, it was a turbonetics TC78
I am surprised none of the 2jz guys have tried them, seems they would work well with that engine, big compressor and smaller turbine
Grr;319326 wrote:
weak sauce, should have gotten the comp 8079!funky_monkey58;319439 wrote:
x2.i probably would have but didn't want to chance it not fitting, i am about positive the comp compressor cover for that turbo is bigger than the GTS
and i already had to do some work with a flap disk to get this one to fit without hitting
