  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • zbrownZ
    zbrownZ
    start
    finish
    • funky_monkey58F
      funky_monkey58F
      funky_monkey58
      Ooooooh pretty.
      • dubbsyD
        dubbsyD
        • dubbsyD
          dubbsyD
          zbrown;318579 wrote:
          ha, thanks Dad!
          and because you say so, i bought a 8pt DOM cage for it this morning! haha, really i did
          only 8?
          • zbrownZ
            zbrownZ
            dubbsy;318583 wrote:
            only 8?
            yeah, i don't want a 10pt in there, maybe later but doubt it
            got the radiator and cooling plumbing done, really like the way it turned out
            heat cycled it a couple times now so i can retorque
            • P
              P
              8pt is only good to 10.0 and or 135mph. 10pt it and be done.
              • zbrownZ
                zbrownZ
                yeah i dont want to tear my dash apart and do the cross bar because i am lazy
                was bored so i built a heat shield for the turbine housing out of some aluminum scraps
                turned out better than i thought it would, looks nice
                and yes i know the retainers go underneath not on top, lol
                • funky_monkey58F
                  funky_monkey58F
                  funky_monkey58
                  Woot for no more blowing off your radiator hoses!
                  • 24valvenotak2
                    24valvenotak2
                    zbrown;319231 wrote:
                    because i am lazy
                    bs.
                    63vette;288530 wrote:
                    • ParkerP
                      ParkerP
                      Needs more cow bell.
                      BlueSRT0483;244555 wrote:
                      Trafik Jamz;260984 wrote:
                      You are right Parker.
                      • zbrownZ
                        zbrownZ
                        24valvenotak;319234 wrote:
                        bs.
                        ha it is truth
                        new turbo showed up from FI
                        got a new Precision 7875 (78hpsh) uses the 75mm gt42's turbine compared to the 68mm F1-68 i had before in the TC
                        should still spool nice and fast but open it up quite a bit for power
                        was torn between a PT88 or the 78 GTS, but i still wanted some decent response so went with the GTS
                        • GrrG
                          GrrG
                          weak sauce, should have gotten the comp 8079!
                          • PSiedTSiP
                            PSiedTSiP
                            Whats your old turbo or did you already sell it?
                            spanish-rice;237125 wrote:
                            • funky_monkey58F
                              funky_monkey58F
                              funky_monkey58
                              x2.
                              • zbrownZ
                                zbrownZ
                                yeah i already sold it, it was a turbonetics TC78
                                I am surprised none of the 2jz guys have tried them, seems they would work well with that engine, big compressor and smaller turbine
                                funky_monkey58;319439 wrote:
                                x2.
                                i probably would have but didn't want to chance it not fitting, i am about positive the comp compressor cover for that turbo is bigger than the GTS
                                and i already had to do some work with a flap disk to get this one to fit without hitting
                                • zbrownZ
                                  zbrownZ
                                  little bit of work and it fits, the compressor cover definitely a good bit larger than the TC
                                  next up is IC plumbing
                                  • zbrownZ
                                    zbrownZ
                                    Got the IC plumbing all done, really like how it turned out.
                                    3" aluminum
                                    • wesholeW
                                      wesholeW
                                      Very nice bro!!
                                      • GrrG
                                        GrrG
                                        wow that looks great, just as I expected
                                        • DaveHD
                                          DaveHD
                                          That turned out really nice, great work.
