  4. 110v to 12v conversion
16 Posts 10 Posters 5.8k Views
  • BookemB
    BookemB
    Bookem
    Most cheaper converters I have seen wouldn't be able to handle much more than just a cd player, here's a couple.
    http://www.northerntool.com/shop/tools/product_200326263_200326263
    http://www.grainger.com/Grainger/TRIPP-LITE-DC-Power-Supply-5JK18?cm_mmc=GoogleBase--Electrical--Power%20Supplies-_-5JK18&ci_src=14110944&ci_sku=5JK18
    Notice the price difference just for jumping from 5.8 to 12 amps, the 5.8 amps is plenty to power a cd player though (we actually have the northenrtool one at work and has worked fine for many years).
    A little bit more you can get a 30 amp, but that still wouldn't power much of an amplifier, I suppose if you're not powering subs just mids and highs it would work.
    http://www.adventurerv.net/parallax-electronic-converter-acdc-distribution-p-2660.html
    Here's a 45 amp converter that might do the job though.
    http://www.americanrvcompany.com/Progressive-Dynamics-PD4045KV-Mighty-Mini-AC-DC-Distribution-Panel-Inteli-Power-Converter-with-Charge-Wizard-45A-Camper-Trailer-RV_p_7681.html
    Legacy GT
    Gmc Suburban
    Hallorann: Fargostreet?
    Hallorann: No, I ain't.
    • JoelJ
      JoelJ
      Generators create "dirty power". You will more than likely take out any kind of advanced electronic while trying to run anything on it . I would say you should get an old home receiver and run it to your speakers. Use one you won't mind frying. just my 2 cents
      • zbrownZ
        zbrownZ
        like joel said about the noise
        the battery charger idea would work fine, but between the generator and charger you are going to get a decent amount of noise
        • legacy-user-351L
          legacy-user-351L
          legacy-user-351
          Ok, so there are a couple good ways to go about this.
          Amateur radio guys have a need for clean 12v DC, and there are a lot of power supplies out there for them. When I competed USACi, I used a Tripp Lite PR40. 32 Amps continuous IIRC, but there are bigger and smaller options to suit your system..
          Another option is a supply meant for a workbench or lab - I use a Pyramid 52KX at home to power my R/C battery chargers. 40 Amps continuous. There are also a bunch of this type of supply built especially for R/Cers.
          If you need big amperage, I'd look here - http://cascadeaudio.com/power_converters/power_converters.htm
          Turkeylord
          '05 Yamaha Zuma - Stock
          • T
            T
            Trafik Jamz
            http://www.theinstallbay.com/product_individual.php?id=1120 something like that would work for you Tony. Car audio grade power supply. You've got my # give me a call or shoot me a PM and we'll discuss pricing.
            701.541.3484
            • PSiedTSiP
              PSiedTSiP
              Awesome input guys. I'm going to check on the thing from Chuck first, looks simple. We are wiring the bus in 110 around the outside walls with like ~3 boxes on each side. We have three amps to run right now, so 45 is the minimum I would try to run IMO. The panel would be nice tho.
              We always run our TV's off the generator while tailgating and haven't had an issue as of yet.
              Zac, get back for a game and we'll show you bachelor party V2 in the west lot.
              spanish-rice;237125 wrote:
              • T
                T
                TomTom
                It's called a power inverter. If you want to clean up the signal going in, use a 1:1 isolation transformer, and possibly capacitors after the power inverter... I was an electronics technician, and that's how it's done in industrial panels. I'd spec out the generator prior to ussuming the power is dirty.
                • legacy-user-351L
                  legacy-user-351L
                  legacy-user-351
                  TomTom;324594 wrote:
                  It's called a power inverter.facepalm
                  Turkeylord
                  • T
                    T
                    Trafik Jamz
                    I think you should post pics of your tailgate rig in the members ride section Tony...
                    701.541.3484
                    • integra_gsr98I
                      integra_gsr98I
                      12v power supply from chuck will do it. They are what are used to drive the 'boom rooms' at every audio shop on the planet.
                      • T
                        T
                        Trafik Jamz
                        Yeah, they went with a power supply from me. Must have done well, the forum quoted them as being the loudest tailgate rig there (paraphrasing a bit) saturday
                        701.541.3484
                        • HandoEXH
                          HandoEXH
                          We will post pics when it's further along. We had only 11 days tp get the rig usable.
                          • integra_gsr98I
                            integra_gsr98I
                            Are you guys taking it to the Bison vs. Goofs game?
                            • PSiedTSiP
                              PSiedTSiP
                              Possibly. We aren't very confident we can make it as is...the motor/tranny is solid but it probably needs tires and who knows what else. Plus, the tailgating at that game is a joke...you have to be a donor or you can tailgate at the fairgrounds which requires you to shuttle there. We are staying like a block from the stadium, so we will see.
                              Yep, worked great. We just had generator issues so eventually the battery started crapping out but the PS worked most of the week while we were playing around with all of it.
                              http://www.inforum.com/event/article/id/332773/publisher_ID/1/
