  4. Boost question
Boost question
13 Posts 6 Posters 1.9k Views
  • zbrownZ
    zbrownZ
    Wtf does that first sentence even mean?
    • PSiedTSiP
      PSiedTSiP
      No kidding.
      So....you are only boosting 4psi but the wastegate is supposed to be 8-9psi? The only way limp mode kills boost is if it has a boost solenoid.
      spanish-rice;237125 wrote:
      • DelSlowD
        DelSlowD
        Put a manual boost controller on it and turn it all the way up. Tune off sounds.
        • JN210J
          JN210J
          JN210
          Means that a stock Z31 turbo is normally around 8-9psi and is normally what everyone runs, Im only curious as to why mine is at 4. I will probably just end up getting a controller and bringing it up to where I want it. I was just wondering if there was something I hadnt checked yet. No boost solonoid on this car...so perhaps it is in its own way "unhappy" and I am just going to manually bring it up anyway.
          *1989 Nissan 300ZX Z31 *
          DelSlow;262050 wrote:
          I like the new JN210
          • PSiedTSiP
            PSiedTSiP
            No. Just no. Do the stock Z31's have a boost control solenoid? I'd assume wastegate is 8psi...if it's not building that much, you probably have a massive leak you can't see(pressure test the system, don't just do a visual test!!!!!!!!!!!!!!!!!!!!!!!!!!!), or your turbo is fucked.
            • JN210J
              JN210J
              JN210
              hmm, wouldnt I be able to hear the leak though? I MIGHT know what I have to do, but I just cant see how any air could escape from how tight the coupler is, but I could put a T-bolt clamp over it though and see what happens.
              • RexwagonR
                RexwagonR
                did u hook the wastegate back up?
                u will have to pressure test it for any leaks. u can build a tester out of pvc piping and an air valve. then use a compressor to pump air in.
                • RexwagonR
                  RexwagonR
                  http://z31.com/faq/turbo.faq.shtml
                  4psi is stock according to here. sounds like wastegate pressure is up to 5psi
                  no offense jeff but 2 mins of google told me that. if it is correct. lol
                  • JN210J
                    JN210J
                    JN210
                    lol, hmm...interesting...so I guess everything is in proper operating order then and I have nothing to worry about. thanks derrick.
                    • RexwagonR
                      RexwagonR
                      it may be working but 4psi is pretty low. u need more boost, period.
                      • JN210J
                        JN210J
                        JN210
                        agreed! lol
                        • DaveHD
                          DaveHD
                          Pull the hose off of the wastegate and let it eat!
                          (j/k btw, don't do that)
