  4. Lots of Honda and Subaru stuff...
4 Posts 2 Posters 872 Views
  • blackcherryTSiB Offline
    blackcherryTSi
    Pics upon request as there is alot of stuff
    Honda:
    D16y7 5 speed tranny (works good no grinds)- 75$
    D16y8 5 speed tranny (3rd gear grind)- 50$
    D16z6 stock oil pan- 5$
    D16 axles (less then 1000 miles)- 75$
    B series intermediate shaft (male x female)- 25$
    D16z6 intake manifold w/ throttle body & fuel rail (x2)- 25$/each
    DNA Motoring strut tower bars front and back (red)- 25$
    D16y8 Valve cover (x2)- 25$/each
    OBD1 ecu to OBD2 jumper harness- 25$
    OBD2 ecu to OBD1 jumper harness- 25$
    Stock z6 throttle body w/ newer map and tps- 15$
    Stock HF exhaust manifold- 5$
    Stock y8 cam gear- 1$
    B series AEM fuel rail (truck bed liner spray painted)- 25$
    Almost brand new aftermarket 68mm tb w/map & tps- 100$
    OBD2 Gsr ecu (p72)- 30$
    Brand new Golden Eagle pro series D16 fuel rail (black)- 100$
    Blox stage 2 y8 cam w/ stock y8 cam- 150$for both
    Innovative rear mount in eg- 50$
    Autometer pro comp ultra lite oil psi gauge (electrical/no sender) 25$
    Autometer pro comp ultra lite a/f ratio gauge- 10$
    New Eg civic front ball joints (lower) TRW part# 104216- 25$ for both
    D16 vtec solenoid- 5$
    Hasport 3 post driver mount- 50$
    3- misc rear t brackets (all d i believe)- 5$each
    Tial wastegate springs 1-yellow 1-green- 2$each
    Stock B series 3 bolt driver mount with red energy inserts- 25$
    Ebay tranny and rear mounts for hydro eg d series- 25$
    D series skunk2 pro intake manifold (bare)- 150$
    STR billit 68mm throttle body w/tps & map- 100$
    13" rims w/ 22"x 8" slicks 4x100 (lots of life left)- 250$
    Subaru:
    Helix High flow catted 3" downpipe- offer
    BPM Tmic (THICK) w/ silicon y pipe- offer
    Greddy catch can (no lines)- 25$
    Stock 04-05 wrx tmic- 75$
    Grimmspeed 3 port BCS 02-05 wrx- 100$
    NRG quick release wheel w/ NRG hub- 300$
    K&N drop in filter- 10$
    02+ gauge surround pod (two spots for gauges)- 30$
    04-05 wrx momo air bag (red inside)- 100$
    Wrx red momo shift knob- 30$
    Cobb intake pipe w/ filter & maf- 100$
    IHI vf-30 turbo (no shaftplay)- 200$
    Perkins turbo part # 2674A402 (no shaft play)- 200$
    Text (218) 731 5017 is preffered... can ship or meet up depending on location THANKS
    1995 Honda Civic
      blackcherryTSi
      Bump! Will change more when I get to a computer but for now
      Slicks- 200$Obo
      Blox y8 stage 2 cam- 100$
      NRG wheel and quick release hub- 200$
      Huge BPM tmic- 200$
      Subaru GM 3 port BCS- 50$
      1995 Honda Civic
      • BassplayerB Offline
        BassplayerB Offline
        Bassplayer
        Do you happen to have a Fuel pressure regulator at all? I might be wrong but I remember a for sale ad awhile ago with one.
        1995 GMC Sierra
          blackcherryTSi
          i have an adjustable obx style one for y8 style fuel rail and a couple stock regular style ones
          1995 Honda Civic
