  4. Electric Fans+Save gas+more hp
17 Posts 9 Posters 5.4k Views
  • bigdogdjB Offline
    bigdogdjB Offline
    bigdogdj
    My buddy got an electric fan out of a ford focus and he said that blows way more air and its more powerful than the cheap aftermarket ones you can get and he said he got his from a junkyard to for $50
    bee_afraid;327157 wrote:
    I've used these guys in the past.
    http://www.flex-a-lite.com/auto/html/electric-fans.html
    or, you could just go the junkyard route. Just make sure that you get something with enough flow and that you install a temp sensor to trigger it on/off when needed. A few years ago I took a job with Nissan and shortly after they had a massive recall on the electric fans out of the Nissan Titan's. I loaded the back of my Jeep up with at least 20-30 electric fan's. There's a couple of boosted Honda's in Louisiana running a Nissan Titan fan now. They were super thin, mounts were easy to mock up, and have great flow.
      Lots of people have ran Taurus fans over the years with great results.
      However, I kinda doubt you will have any noticeable "gains" buy doing this on most vehicles.
      • QuadaQ Offline
        QuadaQ Offline
        Quada
        You won't notice ANY gains unless the new fan moves air more efficiently. The power to drive them has to come from somewhere.
        • RaiderR Offline
          RaiderR Offline
          Raider
          On my 01 5.4l f150...I gained 12hp by removing fan clutch and fan and replacing with Efan
          POWERD BY
            bee_afraid
            Any dyno proof of this?
              Trafik Jamz
              Raider is one of the few people I will take at his word on this. It does make sense though, with a fan clutch and fan the blades are ALWAYS spinning, sometimes more aggressively than others but still always a load on the system to some degree. Electrics kick in and out more efficiently and only come on when needed. I can easily see that being up to 12HP.
              701.541.3484
              • QuadaQ Offline
                QuadaQ Offline
                Quada
                12hp is equivalent to 9000 watts.
                  Yep, as long as the fans aren't running when you do your dyno pull, there is no extra load caused by the electrical drain of the fans.
                  • QuadaQ Offline
                    QuadaQ Offline
                    Quada
                    Do you guys have any sense of how much 12hp is? Especially when we are talking about a little fan! If that fan was replaced with a similar electric fan, that fan would be drawing 750 AMPS! SEVEN HUNDRED FIFTY! AMPS! Either that fan was completely seized or he was lying. This is common sense people.
                      bee_afraid
                      I'm not arguing the gain in HP but I just want to see where the gains came from in the power band. Getting rid of the clutch fan also get's rid of the annoying whoosh under the hood it creates.
                        Trafik Jamz
                        Nope, Dave and his 7.77 second 1/4 mile supra have no idea what 12hp is. Do you understand what rotating mass is? Let's say the standard fan clutch and fan weigh in at 5 pounds for conversation sake. Just by eliminating them you would free up some horsepower... ok, now let's add in the resistance of those blades as they are pushing air through the radiator. That rotating mass has probably gone from the 5 lbs that the parts weigh to over 100 lbs of resistance that has to be spun by the engine itself... add a 100 lbs weight to your crankshaft pulley and see if your car performs better or worse.
                        701.541.3484
                          Trafik Jamz
                          Hmmm... started looking up weights (just to see how close I was) and the fan clutch itself weighs in at 4.6 lbs. The fan weighs in at 4.2 lbs as well. By themselves the 8.8 pounds is quite a bit, though not 12hp by itself. See post above for rest of explanation.
                          http://www.rx7club.com/naturally-aspirated-performance-forum-220/simple-gain-suggestions-n-owners-715386/page5/#post7828394
                          The above was done on an RX-7 everything else was stock except they eliminated the fan clutch and fan and added an electric fan.
                          701.541.3484
                            Just add some Nos
                            /thread
                              • QuadaQ Offline
                                QuadaQ Offline
                                Quada
                                Yes I know what rotating mass is. NEVER would have guessed that they weigh close to 10lbs though. Shit, that's like spinning an extra wheel.
