  4. New Setups?
New Setups?
21 Posts 14 Posters 4.1k Views
  • K
    K
    [email protected];327999 wrote:
    I'm hoping to get stickier rubber at least - was spinning through 1st last year.
    Car seems to be using a little oil - if it turns out to need work there will likely be upgrades...
    What are you using for oil, and how much it burning?
    • K
      K
      I'll probably be playing with a car I don't even own yet. But, likely not much time at the drag strip, we shall see tho.
      • zbrownZ
        zbrownZ
        90rs&01rs;328003 wrote:
        Built my 6 liter upgraded turbo finishing my roll cage ordered an ass load of sfi part's.
        Grr why are you ripping apart the camaro?
        Did u pickup a 480?
        • legacy-user-3898L
          legacy-user-3898L
          legacy-user-3898
          zbrown;328009 wrote:
          Did u pickup a 480?
          I got an st80 it's like the 480 with a race cover i believe. I might be wrong
          • zbrownZ
            zbrownZ
            what turbine is in it?
            • legacy-user-3898L
              legacy-user-3898L
              legacy-user-3898
              they came with different turbine's. all i know is it .96ar and it does have the race cover on it.
              • capitljC
                capitljC
                capitlj
                I let my pickup spend another winter outside in the cold. Maybe now that I got a raise it will migrate down here and the 390 will rumble to life again.
                Mitch Hedberg wrote:
                2004 Impala LS 3.8
                • legacy-user-351L
                  legacy-user-351L
                  legacy-user-351
                  KA-T_240;328007 wrote:
                  What are you using for oil, and how much it burning?Whatever bulk Mobil dino oil Muscatell's uses. I added a whole quart after my run to Minneapolis, but I'm not sure it was topped up when I left. I'm watching it more closely now, just need to put a few more miles on to get a good idea. If I get some time I'll do a compression test and compare to my last readings...
                  EDIT Checked the oil at lunch, confirmed the Minneapolis trip results. 'Bout a 1/2 Qt low after 300 miles. :icon_pale: May try another oil...
                  Turkeylord
                  '05 Yamaha Zuma - Stock
                  • A
                    A
                    ashford
                    nearly identical to this one just with a .96 ar turbine https://turbodaves.com/uploads/S400SX3-80.png
                    as for my race car it has bigger heads and a solid roller, it should get past 6000rpm now and hopefully mid to high 8's.
                    my dd capri is undergoing major renovation at the moment
                    • MisterCMKM
                      MisterCMKM
                      dubbsy;328000 wrote:
                      Piled a bunch of shit in front of it. I ordered some new Caster Camber plates last fall and I think the box is sitting somewhere near the car. There's now half a garage worth of shit stuffed in the storage unit between the car and the door.
                      Give those to me.
                      Just bought a V6 with rims and springs.
                      thrash;315544 wrote:
                      Ford is back :)
                      • HandoEXH
                        HandoEXH
                        Bump. What's new on the streets?
                        • MisterCMKM
                          MisterCMKM
                          I put a new CAI on my car!
                          Ford is back :)
