  4. New Setups?
New Setups?
21 Posts 14 Posters 4.1k Views
  • RexwagonR
    RexwagonR
    I cleaned my K&N, Put air in my drivers side tire, inflated to 49 Psi (10 PLY)
    Hoping to run 19.999
    • InstigatorI
      InstigatorI
      Instigator
      Only thing really affecting performance will be a better tune. No need to dump money into the motor until I've gotten to the point where I'm no longer improving my times.
      -Eric
      Playtime Performance
      '91 Honda Accord - DD
      '09 Honda Ruckus - Matte Gray
      • legacy-user-351L
        legacy-user-351L
        legacy-user-351
        I'm hoping to get stickier rubber at least - was spinning through 1st last year.
        Car seems to be using a little oil - if it turns out to need work there will likely be upgrades...
        Turkeylord
        '05 Yamaha Zuma - Stock
        • dubbsyD
          dubbsyD
          Piled a bunch of shit in front of it. I ordered some new Caster Camber plates last fall and I think the box is sitting somewhere near the car. There's now half a garage worth of shit stuffed in the storage unit between the car and the door.
          • bubbaB
            bubbaB
            Bought a few more parts that look good in my closet, stared at my car a little bit...
            • GrrG
              GrrG
              Built my new motor, trans, put it all in and now I. Cutting the car to pieces and selling everything. So if anyone wants a nice 650hp motor or any f body stuff lmk
              • legacy-user-3898L
                legacy-user-3898L
                legacy-user-3898
                Built my 6 liter upgraded turbo finishing my roll cage ordered an ass load of sfi part's.
                Grr why are you ripping apart the camaro?
                • GrrG
                  GrrG
                  Getting out man, no need for it I've got a tbss I can mess with
                  • K
                    K
                    What are you using for oil, and how much it burning?
                    • K
                      K
                      I'll probably be playing with a car I don't even own yet. But, likely not much time at the drag strip, we shall see tho.
                      • zbrownZ
                        zbrownZ
                        Did u pickup a 480?
                        • legacy-user-3898L
                          legacy-user-3898L
                          legacy-user-3898
                          zbrown;328009 wrote:
                          Did u pickup a 480?
                          I got an st80 it's like the 480 with a race cover i believe. I might be wrong
                          • zbrownZ
                            zbrownZ
                            what turbine is in it?
                            • legacy-user-3898L
                              legacy-user-3898L
                              legacy-user-3898
                              they came with different turbine's. all i know is it .96ar and it does have the race cover on it.
                              • capitljC
                                capitljC
                                capitlj
                                I let my pickup spend another winter outside in the cold. Maybe now that I got a raise it will migrate down here and the 390 will rumble to life again.
                                Mitch Hedberg wrote:
                                2004 Impala LS 3.8
                                • legacy-user-351L
                                  legacy-user-351L
                                  legacy-user-351
                                  KA-T_240;328007 wrote:
                                  What are you using for oil, and how much it burning?Whatever bulk Mobil dino oil Muscatell's uses. I added a whole quart after my run to Minneapolis, but I'm not sure it was topped up when I left. I'm watching it more closely now, just need to put a few more miles on to get a good idea. If I get some time I'll do a compression test and compare to my last readings...
                                  EDIT Checked the oil at lunch, confirmed the Minneapolis trip results. 'Bout a 1/2 Qt low after 300 miles. :icon_pale: May try another oil...
                                  Turkeylord
                                  • A
                                    A
                                    ashford
                                    nearly identical to this one just with a .96 ar turbine https://turbodaves.com/uploads/S400SX3-80.png
                                    as for my race car it has bigger heads and a solid roller, it should get past 6000rpm now and hopefully mid to high 8's.
                                    my dd capri is undergoing major renovation at the moment
                                    • MisterCMKM
                                      MisterCMKM
                                      Give those to me.
                                      Just bought a V6 with rims and springs.
                                      thrash;315544 wrote:
                                      Ford is back :)
                                      • HandoEXH
                                        HandoEXH
                                        Bump. What's new on the streets?
                                        • MisterCMKM
                                          MisterCMKM
                                          I put a new CAI on my car!
                                          Ford is back :)
