  4. New Setups?
New Setups?
21 Posts 14 Posters 4.1k Views
  • C
    C
    Chirp5957
    what have you all done this winter to your ride?
    what do you hope to be running at the track this year?
    1996 cobra 13.20 @106
    4.10 gears
    short throw shift
    off road x pipe
    BBK Cold Air
    Diablo chip
    BBK LT
    • RexwagonR
      RexwagonR
      I cleaned my K&N, Put air in my drivers side tire, inflated to 49 Psi (10 PLY)
      Hoping to run 19.999
      • InstigatorI
        InstigatorI
        Instigator
        Only thing really affecting performance will be a better tune. No need to dump money into the motor until I've gotten to the point where I'm no longer improving my times.
        -Eric
        Playtime Performance
        '91 Honda Accord - DD
        '09 Honda Ruckus - Matte Gray
        • legacy-user-351L
          legacy-user-351L
          legacy-user-351
          I'm hoping to get stickier rubber at least - was spinning through 1st last year.
          Car seems to be using a little oil - if it turns out to need work there will likely be upgrades...
          Turkeylord
          '05 Yamaha Zuma - Stock
          • dubbsyD
            dubbsyD
            Piled a bunch of shit in front of it. I ordered some new Caster Camber plates last fall and I think the box is sitting somewhere near the car. There's now half a garage worth of shit stuffed in the storage unit between the car and the door.
            • bubbaB
              bubbaB
              Bought a few more parts that look good in my closet, stared at my car a little bit...
              • GrrG
                GrrG
                Built my new motor, trans, put it all in and now I. Cutting the car to pieces and selling everything. So if anyone wants a nice 650hp motor or any f body stuff lmk
                • legacy-user-3898L
                  legacy-user-3898L
                  legacy-user-3898
                  Built my 6 liter upgraded turbo finishing my roll cage ordered an ass load of sfi part's.
                  Grr why are you ripping apart the camaro?
                  • GrrG
                    GrrG
                    Getting out man, no need for it I've got a tbss I can mess with
                    • K
                      K
                      What are you using for oil, and how much it burning?
                      • K
                        K
                        I'll probably be playing with a car I don't even own yet. But, likely not much time at the drag strip, we shall see tho.
                        • zbrownZ
                          zbrownZ
                          Did u pickup a 480?
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            zbrown;328009 wrote:
                            Did u pickup a 480?
                            I got an st80 it's like the 480 with a race cover i believe. I might be wrong
                            • zbrownZ
                              zbrownZ
                              what turbine is in it?
                              • legacy-user-3898L
                                legacy-user-3898L
                                legacy-user-3898
                                they came with different turbine's. all i know is it .96ar and it does have the race cover on it.
                                • capitljC
                                  capitljC
                                  capitlj
                                  I let my pickup spend another winter outside in the cold. Maybe now that I got a raise it will migrate down here and the 390 will rumble to life again.
                                  Mitch Hedberg wrote:
                                  2004 Impala LS 3.8
                                  • legacy-user-351L
                                    legacy-user-351L
                                    legacy-user-351
                                    KA-T_240;328007 wrote:
                                    What are you using for oil, and how much it burning?Whatever bulk Mobil dino oil Muscatell's uses. I added a whole quart after my run to Minneapolis, but I'm not sure it was topped up when I left. I'm watching it more closely now, just need to put a few more miles on to get a good idea. If I get some time I'll do a compression test and compare to my last readings...
                                    EDIT Checked the oil at lunch, confirmed the Minneapolis trip results. 'Bout a 1/2 Qt low after 300 miles. :icon_pale: May try another oil...
                                    Turkeylord
                                    • A
                                      A
                                      ashford
                                      nearly identical to this one just with a .96 ar turbine https://turbodaves.com/uploads/S400SX3-80.png
                                      as for my race car it has bigger heads and a solid roller, it should get past 6000rpm now and hopefully mid to high 8's.
                                      my dd capri is undergoing major renovation at the moment
                                      • MisterCMKM
                                        MisterCMKM
                                        Give those to me.
                                        Just bought a V6 with rims and springs.
                                        thrash;315544 wrote:
                                        Ford is back :)
                                        • HandoEXH
                                          HandoEXH
                                          Bump. What's new on the streets?
