  4. choosing a travel trailer
5 Posts 3 Posters 1.7k Views
    What are some must have's you guys have run into? looking for something 3000-3500 lbs. Going to be towing with 13 Pilot with 4500lb max cap. Will have trailer brake controller as well. I assume to get anything decently sized I am going to need to do a pop-up which is fine. Going to try to watch the paper/craigslist this fall and "steal" one. Any advice or leads on one would be awesome. Would like room to sleep 4-6 adults, and A/C
      How far are you going to travel? What amenities are important to you? Do you want to dry camp or are you going to have hookups?
        4,500lbs will add up pretty quick in any type of travel trailer. You should be looking for 3,500lb dry weight trailers.
          going to be doing a mixture of both dry camping and hookups. mainly dry camping at brainerd, other than that, we will have hook ups. some sort of shower and toilet. cooking is not necessary as I usually try to grill everything. if its a pop up i'd like the ability to park motorcycle or 4 wheeler on top or pull it behind in a pup trailer.
            make sure you get plenty of water, gray and black tanks... nothing worse than having the black tank fill up on you. :-0
