  4. dead car...should be a simple fix??
19 Posts 8 Posters 1.3k Views
    700-800 .....yeah right go buy a AC Delco Fuel pump and have it installed somehwere else..
    • J Offline
      J Offline
      jake
      What year Blazer is it?
      Check to see if you have spark, and listen to hear if your fuel pump is running when you turn the key on
      My first guess would be the ignition module (under the dist. cap and rotor ~ new for around $30-$40)
      They usually cut out temporarily at high loads or high RPM (due to heat), and eventually go out totally
      Jake
      Jake
        The guy that bought my blazer had the pump go out and it cost him $7xx.00 some bucks for the OEM as I stated.
        I've priced out the pumps before I really don't think you're gonna do it for under 500 bucks parts and labor. BUT, who knows if that is even the issue.
          I had the same thing happen to my Blazer and it was the fuel pump going out. It isn't that bad for it to be fixed mine costed $600 because I got a whole new gas tank at the same time.
          • jct_4628J Offline
            jct_4628J Offline
            jct_4628
            so, how do I tell if its the fuel pump? And if it is, do you all think you could talk me through a home replacement? I need my car for work, so please respond fast! You guys rule!
            Jason
            -06 WRX
            -95 CBR 600F3
            701-541-2568
            • jct_4628J Offline
              jct_4628J Offline
              jct_4628
              so I just went out (9:00 am) to check if I had spark. As far as I can tell all my plugs are right between the engine and the firewall. So I cant even fucking get my hand back there to get the plug wires off. Why the fuck did I take a job that depends on my pos? Any ideas fs?
              Jason
              -06 WRX
              -95 CBR 600F3
              701-541-2568
                thats a chevy engine for ya....pretty sure ur not gettin any fuel tho.....bring it to a shop.
                • J Offline
                  J Offline
                  jake
                  Again, what year is your Blazer? I'm assuming 4.3 V6. Vortec or TBI?
                  You should hear your fuel pump (a little whining noise in the fuel tank). The pump should run for a few seconds when you first turn on the key, and then go again after cranking for a while. If you want to check the fuel pressure, there should be a schrader valve (looks like a tire valve stem) on the fuel rail up by the injectors. If you don't have a fuel pressure gage, you can put a rag over the valve and poke the center with a screwdriver. It will squirt like crazy if there's any fuel pressure in the system.
                  Jake
                  Jake
                  • jct_4628J Offline
                    jct_4628J Offline
                    jct_4628
                    Jake1995....look at my sig hehehe
                    Jason
                    -06 WRX
                    -95 CBR 600F3
                    701-541-2568
                    • F Offline
                      F Offline
                      fanaticrockford
                      you can also spray some starting fluid in the intake if it fires you have a fuel problem. also check out http://blazinlow.com/
                      • My NOvaM Offline
                        My NOvaM Offline
                        My NOva
                        Check Ur Fuses Allmost All Chevys Have A Main Engine Fuses That Will Let It Crank And Crank And Not Fire Up
                        Hey Tina come get some hamm
                        • dubbsyD Offline
                          dubbsyD Offline
                          no, it says that your bike is a 95.. not the blazer. 😉
                          • jct_4628J Offline
                            jct_4628J Offline
                            jct_4628
                            It was a fuse......fawk
                            Jason
                            -06 WRX
                            -95 CBR 600F3
                            701-541-2568
                              well that is good news then.
                                holy fucking shit....Nova was the only one right!
