  4. dead car...should be a simple fix??
19 Posts 8 Posters 1.1k Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    so I just went out (9:00 am) to check if I had spark. As far as I can tell all my plugs are right between the engine and the firewall. So I cant even fucking get my hand back there to get the plug wires off. Why the fuck did I take a job that depends on my pos? Any ideas fs?
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
      thats a chevy engine for ya....pretty sure ur not gettin any fuel tho.....bring it to a shop.
      • J Offline
        J Offline
        jake
        Again, what year is your Blazer? I'm assuming 4.3 V6. Vortec or TBI?
        You should hear your fuel pump (a little whining noise in the fuel tank). The pump should run for a few seconds when you first turn on the key, and then go again after cranking for a while. If you want to check the fuel pressure, there should be a schrader valve (looks like a tire valve stem) on the fuel rail up by the injectors. If you don't have a fuel pressure gage, you can put a rag over the valve and poke the center with a screwdriver. It will squirt like crazy if there's any fuel pressure in the system.
        Jake
        Jake
        • jct_4628J Offline
          jct_4628J Offline
          jct_4628
          Jake1995....look at my sig hehehe
          Jason
          -06 WRX
          -95 CBR 600F3
          701-541-2568
          • F Offline
            F Offline
            fanaticrockford
            you can also spray some starting fluid in the intake if it fires you have a fuel problem. also check out http://blazinlow.com/
            • My NOvaM Offline
              My NOvaM Offline
              My NOva
              Check Ur Fuses Allmost All Chevys Have A Main Engine Fuses That Will Let It Crank And Crank And Not Fire Up
              Hey Tina come get some hamm
              • dubbsyD Offline
                dubbsyD Offline
                no, it says that your bike is a 95.. not the blazer. 😉
                • jct_4628J Offline
                  jct_4628J Offline
                  jct_4628
                  It was a fuse......fawk
                  Jason
                  -06 WRX
                  -95 CBR 600F3
                  701-541-2568
                    well that is good news then.
                      holy fucking shit....Nova was the only one right!
