  4. Running Lean
Running Lean
31 Posts 13 Posters 3.2k Views
    maybe your injectors are clogged? does it ever feel laggy? perhaps there's a bottleneck in your fuel system? i'd run a couple of bottles of injector cleaner through and rod on it really aggressively for a few hours/days, make sure your new plugs are gapped properly. if that doesn't work, get it professionally checked out
    • harwood39H Offline
      harwood39H Offline
      harwood39
      I would bring it to the dealer to get it tuned. They are the only place i know of that can do it.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        your car is mechanically stock, there is no tuning required. the only problems you have are more than likely hardware (unless there was some sort of malfunction with the ecu).
        • dubbsyD Offline
          dubbsyD Offline
          you need a tune UP, not a tune. Like they're saying, if your car is that close to stock...you've got problems outside of a tune.
          I'll assume there's no CEL? weird that a car would be running that lean and have no CEL (or are civics like that?)
          that exhaust cat back? ...or were you screwing with O2 sensors and cats?
            Looks to me like spark plugs out of a relatively stock car.
            My integra always had plugs that looked like that when it was stock.
            As long as they're not speckled, you're fine.
              tqisking
              I agree with integra....plugs look fine but maybe 1 heat range to hot....if there are no black specs then let it run....
                harwood39H Offline
                harwood39
                no black specs, i dont need a tune up, if i need any thing, they need to adjust the injectors, i had a rich problem with my old car, they just plug into the ECU, and adjust the injectors.
                Fargo, ND 58103
                701-429-3686
                  I second the heat range idea. I would rather spend six bucks on new plugs then sixty taking it to the dealer only to find nothing is wrong.
                    harwood39H Offline
                    harwood39
                    im doin the plugs first. than if that doesnt help im taking it in.
                    Fargo, ND 58103
                    701-429-3686
                      Umm, since when can someone plug into your car and "adjust" your injectors? Is this something new? Never have I heard of such a thing unless you have some type of stand alone engine management or a modified ecu of some sort.
                        harwood39H Offline
                        harwood39
                        wow, where have you been, they have been able to do that since they started using fuel injection. How do you think they can do a tune up, they have to do it in a tune up depending on how its running. Go to a dealership and ask around.
                        Fargo, ND 58103
                        701-429-3686
                          i think what your talkin about is a scan tool you gave everyone the wrong perception of what you were talkin about im assuming...i dont think you can "adjust" the injectors...if you can wow i guess i learned somethin new but ive done pretty extensive work with scantools and never been taught that you can just "adjust" them...i know you can look and see the pulse width, fuel trim etc...keep in mind they used fuel injection back in the 50s and 60s in the corvette and prolly some other vehicles you might wanna watch your statement
                            Haha. If you knew anything about Honda ecu's you would know that they cannot "adjust" your injectors at the dealership. But from what it seems you know everything about Hondas. Just because your car has fuel injection doesn't mean your car's "fuel injectors can be modified."
                            Tell me how the VW dealers adjust fuel injection settings on a car with mechanical fuel injection?
                            When you answer that let me know.
                              better yet lets see the reciept from the last time you took your car to the dealership and had them adjust the pulse...then we will have something else to laught at....you getting raped.
                                harwood39H Offline
                                harwood39
                                haha, i wasnt thinking straight, but the can adjust the pulse, at least on nissans. As long as its ELECTRONIC FUEL INJECTION. I was goin to get it done on my 300ZX right before i blew the motor, cause it was running supper rich. I know absolutely nothing about hondas. and its not a couple hundred dollar scan tool they use, its a few thousand dollar computer, i was goin to buy one of these for my 300ZX but i didnt have $6000.
                                Fargo, ND 58103
                                701-429-3686
                                  yep we got one of them in out shop along with a lift they are about 6500 for the computer.
                                    i dont remember the last time i used a couple hundred dollar scantool...the last time i checked they were a couple thousand even for the shitty ford genstar...
                                      If dealers were adjusting fuel tables across the entire rev range for both high and low throttle on cars without the use of the dyno or any ecu modifications, why do people switch to standalone engine managements? Damn those crazy dealers have some crazy stuff these days.
                                      Having used a 5000+ dollar scan tool they're not that impressive for what they cost. They clear codes, read codes, and check sensors, but nowhere did I see any way to adjust ecu settings for any of the vehicles I used it on.
                                        based on the description of these expensive scan tools, they sound a lot like the datalogging stuff from pocketlogger... cost me less than 200 including a palm pilot
                                          pin
                                          The Ford STAR tester I've used is able to make ECU adjustments with the correct memory card inserted. Of course, you have to spend a lot of money on those cards and they only cover a certain range of ECU programs. I don't know what they are capable of editing though.
                                          Barry
