First Time
Id rather have the vette. a boosted honda? hooraw. a vette, is pimp. even though i am an import guy myself.
Big-D wrote:
wecome to fargostreet... the vette's a cool car... i say buy a honda, do an h22 swap and boost it, then you will allmost be as fast as a vette but with pride that the 4 cylinder will wax most cars with 8 cylinders.coming from somebody who drives a honda and thinks h22 swaps are god
I dont even think its a question
Big-D wrote:
well if you can find insurance for the vett as cheap as you can for a honda i would love to know... and i garuntee that you can make an import handle better than a vetteGonna be tough to make a FWD one handle better, understeer SUCKS in FWD (or AWD for that matter) hence the reason that race cars are RWD
Welcome to the site
if you get the honda over the vette or still debating...prepared to get laughed at.
I say Vette or... if its close to what the 99 vette is get an 05 Mustang GT and add a blower. Youll WAX vettes all day long, and they handle really good. Not like a vette but with a couple of aftermarket upgrades they will out handle a vette.
And I personally think that the new mustangs look better then vettes.
BTW welcome to the site!
Flowcus wrote:
I say Vette or... if its close to what the 99 vette is get an 05 Mustang GT and add a blower. Youll WAX vettes all day long, and they handle really good. Not like a vette but with a couple of aftermarket upgrades they will out handle a vette.And I personally think that the new mustangs look better then vettes.
Opinions.Plus, and 05 GT would cost MORE than a 99 vette. Just throw a supercharger on the vette, and its bye bye GT.
you wouldnt even need to throw a blower on a vette to beat a GT.....but if its a 99 vette that your getting average price tag is probaly around 25-30k depending on seller and etc. and 05 GT's are actually around the same price if you look.
1999 Corvette specs...
- 5,665 cc 5.7 liters 8 V front longitudinal engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, light alloy block, light alloy head, overhead valve and two valves per cylinder
- Premium unleaded fuel
- Fuel economy EPA highway (l/100km): 9.4
- Multi-point injection fuel system
- 72 liter fuel tank
- Power: 345 HP @ 5,600 rpm; 350 ft lb , @ 4,400 rpm
vs. 05 GT
90° Aluminium Block and Heads
Gear chain-driven SOHC, 3 valves/cyl, hydraulic lifters, variable intake- and exhaust-valve timing
281 CI / 4606 CC
300 BHP / @ 6000 RPM
315 FT LBS / @ 4500 RPM
6000 RPM
Bore 3.55 IN / 90 MM
Stroke 3.54 IN / 90 MM
9.8:1 compression
Aluminum block and aluminum headsSo based on those #'s vette=faster....but both have = tuning capabilities and just depends if your a ford guy or chevy
both also come stock with great handiling.
vette=
Wishbone front suspension with stabilizer bar independent with leaf springs , multi-link rear suspension with stabilizer bar independent with leaf springsGT Front suspensions set up-MacPherson struts, coil springs, anti-roll bar
Rear-Rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar.
In the long run I think the stang would take the vette out. Lower compression stock, with valve timing and more valves per cyl.
Not to mention the stang is probably lighter then the vette. And the new 06 mustang GT500 is going to kill the new vette ZO6 ( detuned version of the 5.0 in the ford GT supercar in the new GT500 otherwise known as the SVT Cobra )
Flowcus wrote:
In the long run I think the stang would take the vette out. Lower compression stock, with valve timing and more valves per cyl.Not to mention the stang is probably lighter then the vette. And the new 06 mustang GT500 is going to kill the new vette ZO6 ( detuned version of the 5.0 in the ford GT supercar in the new GT500 otherwise known as the SVT Cobra )
I disagree with everything you say here.
