  2. Introductions
  3. Introductions
  4. First Time
First Time
34 Posts 14 Posters 2.8k Views
  • LT1L
    LT1L
    LT1
    suggesting a honda over a Vette is....LAMEEE! If ur a domestic fan then Corvettes r nice.
    • 94NDTA9
      94NDTA9
      You don't even really need to be a domestic fan to like a vette. Kinda like you don't need to be an import fan to like a supra or an NSX.
      • wesholeW
        wesholeW
        Get the Vette. You can make the Honda as fast as one but good luck making it handle like one. Not to mention they are pretty pimp to boot.
        • 24valvenotak2
          24valvenotak2
          Big-D wrote:
          wecome to fargostreet... the vette's a cool car... i say buy a honda, do an h22 swap and boost it, then you will allmost be as fast as a vette but with pride that the 4 cylinder will wax most cars with 8 cylinders.
          coming from somebody who drives a honda and thinks h22 swaps are god
          I dont even think its a question
          63vette;288530 wrote:
          • Big-DB
            Big-DB
            Big-D
            well if you can find insurance for the vett as cheap as you can for a honda i would love to know... and i garuntee that you can make an import handle better than a vette
              Gonna be tough to make a FWD one handle better, understeer SUCKS in FWD (or AWD for that matter) hence the reason that race cars are RWD
              • Big-DB
                Big-DB
                Big-D
                i seen some awd cars handle better than rear
                • 94NDTA9
                  94NDTA9
                  I have too.
                  But there is a reason most race cars are RWD.
                  • hondagirl17H
                    hondagirl17H
                    hondagirl17
                    Welcome to the site
                    ~ Laura
                    All stock....for now!
                    01 GSX-R600
                    ~ :cool:
                    • STiSchuckyS
                      STiSchuckyS
                      if you get the honda over the vette or still debating...prepared to get laughed at.
                        Oh, don't get me wrong, there are ALWAYS exceptions to the rule and for some applications AWD or FWD may be adventageous. Generally speaking however, it is hard to beat AWD for handling capabilities.
                        • 94NDTA9
                          94NDTA9
                          For the average driver, AWD owns.
                          • FlowcusF
                            FlowcusF
                            Flowcus
                            I say Vette or... if its close to what the 99 vette is get an 05 Mustang GT and add a blower. Youll WAX vettes all day long, and they handle really good. Not like a vette but with a couple of aftermarket upgrades they will out handle a vette.
                            And I personally think that the new mustangs look better then vettes.
                            BTW welcome to the site! 😄
                            I ride random bitches.
                            • 94NDTA9
                              94NDTA9
                              Opinions.
                              Plus, and 05 GT would cost MORE than a 99 vette. Just throw a supercharger on the vette, and its bye bye GT.
                              • Pony_RacerP
                                Pony_RacerP
                                Pony_Racer
                                you wouldnt even need to throw a blower on a vette to beat a GT.....but if its a 99 vette that your getting average price tag is probaly around 25-30k depending on seller and etc. and 05 GT's are actually around the same price if you look.
                                1999 Corvette specs...
                                • 5,665 cc 5.7 liters 8 V front longitudinal engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, light alloy block, light alloy head, overhead valve and two valves per cylinder
                                • Premium unleaded fuel
                                • Fuel economy EPA highway (l/100km): 9.4
                                • Multi-point injection fuel system
                                • 72 liter fuel tank
                                • Power: 345 HP @ 5,600 rpm; 350 ft lb , @ 4,400 rpm
                                  vs. 05 GT
                                90° Aluminium Block and Heads
                                Gear chain-driven SOHC, 3 valves/cyl, hydraulic lifters, variable intake- and exhaust-valve timing
                                281 CI / 4606 CC
                                300 BHP / @ 6000 RPM
                                315 FT LBS / @ 4500 RPM
                                6000 RPM
                                Bore 3.55 IN / 90 MM
                                Stroke 3.54 IN / 90 MM
                                9.8:1 compression
                                Aluminum block and aluminum heads
                                So based on those #'s vette=faster....but both have = tuning capabilities and just depends if your a ford guy or chevy 😄
                                both also come stock with great handiling.
                                vette=
                                Wishbone front suspension with stabilizer bar independent with leaf springs , multi-link rear suspension with stabilizer bar independent with leaf springs
                                GT Front suspensions set up-MacPherson struts, coil springs, anti-roll bar
                                Rear-Rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar.
                                R.I.P 1QK_PNY:icon_salut:
                                • FlowcusF
                                  FlowcusF
                                  Flowcus
                                  In the long run I think the stang would take the vette out. Lower compression stock, with valve timing and more valves per cyl.
                                  Not to mention the stang is probably lighter then the vette. And the new 06 mustang GT500 is going to kill the new vette ZO6 ( detuned version of the 5.0 in the ford GT supercar in the new GT500 otherwise known as the SVT Cobra )
                                  • 94NDTA9
                                    94NDTA9
                                    I disagree with everything you say here.
                                    • 94NDTA9
                                      94NDTA9
                                      The new Z06 will be right on the heels of the Ford GT. It weighs over 200 lbs less, only 50 less hp, 25 less lbft of TQ, Has a better weight distribution, and has allready provne in the C6 models, that it handles remarkable.
                                      The only thing the GT500 will be competing with will be the new GTO.
                                      Just wait till GM puts FI on the C6 Z06 🙂
                                      • Pony_RacerP
                                        Pony_RacerP
                                        Pony_Racer
                                        05 GT is about 3,400lbs vette is around 3200 or so. But then again the vette was aerodynamically built for racing where as the GT was not completely designed for that purpose hence the weight differences.
                                        • Pony_RacerP
                                          Pony_RacerP
                                          Pony_Racer
                                          07 GT 500 specs....
                                          V-8
                                          Manufacturing location Romeo, Michigan
                                          Configuration Iron Block and Aluminum Heads
                                          Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
                                          Exhaust manifold Cast iron
                                          Crankshaft Forged steel
                                          Throttle body Dual 55 mm, electronic
                                          Valvetrain DOHC, 4 valves per cylinder
                                          Valve diameter Intake: 37.0 mm
                                          Exhaust: 32.0 mm
                                          Pistons Forged aluminum
                                          Connecting rods Cracked forged steel I-beams
                                          Ignition Coil-on-plug
                                          Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
                                          Displacement 330 cu. in. / 5,409 cc
                                          Horsepower More than 450
                                          Torque 450 lb.-ft
                                          also will be running stock at about 8.5 PSi
                                          06 Zo6
                                          427 cid Aluminum C5R blueprinted block
                                          512HP with advertised 500HP
                                          Aluminum block w/104.8mm bores & pressed-in liners
                                          Forged steel crankshaft with 101.6mm stroke
                                          6-bolt forged steel main bearing caps
                                          Titanium connecting rods
                                          Cast Eutectic aluminum flat-top pistons
                                          Racing-derived CNC-ported aluminum heads w/ 70cc chambers
                                          56mm titanium intake valves
                                          41mm sodium-filled exhaust valves
                                          11.0:1 compression ratio
                                          Composite manifold with 90mm single-bore throttle body
                                          Camshaft with 15mm (.591-inch) lift
                                          Dry-sump oiling system
                                          7000rpm redline
                                          Weight: 2900 lbs
                                          Rear spoiler
                                          Functional air induction from hood vent
                                          Hydroformed aluminum chassis*
