  2. Introductions
  3. Introductions
  4. First Time
First Time
34 Posts 14 Posters 2.8k Views
  • STiSchuckyS
    STiSchuckyS
    if you get the honda over the vette or still debating...prepared to get laughed at.
      Oh, don't get me wrong, there are ALWAYS exceptions to the rule and for some applications AWD or FWD may be adventageous. Generally speaking however, it is hard to beat AWD for handling capabilities.
      • 94NDTA9
        94NDTA9
        For the average driver, AWD owns.
        • FlowcusF
          FlowcusF
          Flowcus
          I say Vette or... if its close to what the 99 vette is get an 05 Mustang GT and add a blower. Youll WAX vettes all day long, and they handle really good. Not like a vette but with a couple of aftermarket upgrades they will out handle a vette.
          And I personally think that the new mustangs look better then vettes.
          BTW welcome to the site! 😄
          I ride random bitches.
          • 94NDTA9
            94NDTA9
            Opinions.
            Plus, and 05 GT would cost MORE than a 99 vette. Just throw a supercharger on the vette, and its bye bye GT.
            • Pony_RacerP
              Pony_RacerP
              Pony_Racer
              you wouldnt even need to throw a blower on a vette to beat a GT.....but if its a 99 vette that your getting average price tag is probaly around 25-30k depending on seller and etc. and 05 GT's are actually around the same price if you look.
              1999 Corvette specs...
              • 5,665 cc 5.7 liters 8 V front longitudinal engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, light alloy block, light alloy head, overhead valve and two valves per cylinder
              • Premium unleaded fuel
              • Fuel economy EPA highway (l/100km): 9.4
              • Multi-point injection fuel system
              • 72 liter fuel tank
              • Power: 345 HP @ 5,600 rpm; 350 ft lb , @ 4,400 rpm
                vs. 05 GT
              90° Aluminium Block and Heads
              Gear chain-driven SOHC, 3 valves/cyl, hydraulic lifters, variable intake- and exhaust-valve timing
              281 CI / 4606 CC
              300 BHP / @ 6000 RPM
              315 FT LBS / @ 4500 RPM
              6000 RPM
              Bore 3.55 IN / 90 MM
              Stroke 3.54 IN / 90 MM
              9.8:1 compression
              Aluminum block and aluminum heads
              So based on those #'s vette=faster....but both have = tuning capabilities and just depends if your a ford guy or chevy 😄
              both also come stock with great handiling.
              vette=
              Wishbone front suspension with stabilizer bar independent with leaf springs , multi-link rear suspension with stabilizer bar independent with leaf springs
              GT Front suspensions set up-MacPherson struts, coil springs, anti-roll bar
              Rear-Rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar.
              R.I.P 1QK_PNY:icon_salut:
              • FlowcusF
                FlowcusF
                Flowcus
                In the long run I think the stang would take the vette out. Lower compression stock, with valve timing and more valves per cyl.
                Not to mention the stang is probably lighter then the vette. And the new 06 mustang GT500 is going to kill the new vette ZO6 ( detuned version of the 5.0 in the ford GT supercar in the new GT500 otherwise known as the SVT Cobra )
                • 94NDTA9
                  94NDTA9
                  I disagree with everything you say here.
                  • 94NDTA9
                    94NDTA9
                    The new Z06 will be right on the heels of the Ford GT. It weighs over 200 lbs less, only 50 less hp, 25 less lbft of TQ, Has a better weight distribution, and has allready provne in the C6 models, that it handles remarkable.
                    The only thing the GT500 will be competing with will be the new GTO.
                    Just wait till GM puts FI on the C6 Z06 🙂
                    • Pony_RacerP
                      Pony_RacerP
                      Pony_Racer
                      05 GT is about 3,400lbs vette is around 3200 or so. But then again the vette was aerodynamically built for racing where as the GT was not completely designed for that purpose hence the weight differences.
                      • Pony_RacerP
                        Pony_RacerP
                        Pony_Racer
                        07 GT 500 specs....
                        V-8
                        Manufacturing location Romeo, Michigan
                        Configuration Iron Block and Aluminum Heads
                        Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
                        Exhaust manifold Cast iron
                        Crankshaft Forged steel
                        Throttle body Dual 55 mm, electronic
                        Valvetrain DOHC, 4 valves per cylinder
                        Valve diameter Intake: 37.0 mm
                        Exhaust: 32.0 mm
                        Pistons Forged aluminum
                        Connecting rods Cracked forged steel I-beams
                        Ignition Coil-on-plug
                        Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
                        Displacement 330 cu. in. / 5,409 cc
                        Horsepower More than 450
                        Torque 450 lb.-ft
                        also will be running stock at about 8.5 PSi
                        06 Zo6
                        427 cid Aluminum C5R blueprinted block
                        512HP with advertised 500HP
                        Aluminum block w/104.8mm bores & pressed-in liners
                        Forged steel crankshaft with 101.6mm stroke
                        6-bolt forged steel main bearing caps
                        Titanium connecting rods
                        Cast Eutectic aluminum flat-top pistons
                        Racing-derived CNC-ported aluminum heads w/ 70cc chambers
                        56mm titanium intake valves
                        41mm sodium-filled exhaust valves
                        11.0:1 compression ratio
                        Composite manifold with 90mm single-bore throttle body
                        Camshaft with 15mm (.591-inch) lift
                        Dry-sump oiling system
                        7000rpm redline
                        Weight: 2900 lbs
                        Rear spoiler
                        Functional air induction from hood vent
                        Hydroformed aluminum chassis*
                        • 94NDTA9
                          94NDTA9
                          The Z06 is 3030 specifically, and has more HP and TQ. Most places I have been reading have said the curb weight of the Gt500 is around 3600 lbs.
                          HERE IS ONE OF THEM
                          They are NO WHERE in the same league, especially in the handling department.
                          • Pony_RacerP
                            Pony_RacerP
                            Pony_Racer
                            was talking about the 99 not the new Z06 :D....my bad
                            • Pony_RacerP
                              Pony_RacerP
                              Pony_Racer
                              also price of the GT500 will be around 40k.
                              Z06 is estimated 50-70k.......
                                lingenfelter corvette owns all...0-60 in 1.8 seconds??
                                • Pony_RacerP
                                  Pony_RacerP
                                  Pony_Racer
                                  http://www.fast-autos.net/ford/fordbossmustang.html
                                  1.9...not bad for a heavy stang 😄
                                  and actually the vette was 1.9 too 😄
                                  http://www.fast-autos.net/lingenfelter/lingenfelter427tt.html
                                  • 94NDTA9
                                    94NDTA9
                                    I would take my car to ARE before LPE.
                                    • P
                                      P
                                      pjm710
                                      I was thinking the vett and then next summer going with a procharger at like 5 or 7 psi. insurance not a problem its around 100 month for me.
                                      Its not where the car came from its how fast it can get away from there
