  2. Introductions
  3. Introductions
  4. First Time
First Time
34 Posts 14 Posters 2.8k Views
  • 94NDTA9
    94NDTA9
    The new Z06 will be right on the heels of the Ford GT. It weighs over 200 lbs less, only 50 less hp, 25 less lbft of TQ, Has a better weight distribution, and has allready provne in the C6 models, that it handles remarkable.
    The only thing the GT500 will be competing with will be the new GTO.
    Just wait till GM puts FI on the C6 Z06 🙂
    • Pony_RacerP
      Pony_RacerP
      Pony_Racer
      05 GT is about 3,400lbs vette is around 3200 or so. But then again the vette was aerodynamically built for racing where as the GT was not completely designed for that purpose hence the weight differences.
      R.I.P 1QK_PNY:icon_salut:
      • Pony_RacerP
        Pony_RacerP
        Pony_Racer
        07 GT 500 specs....
        V-8
        Manufacturing location Romeo, Michigan
        Configuration Iron Block and Aluminum Heads
        Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
        Exhaust manifold Cast iron
        Crankshaft Forged steel
        Throttle body Dual 55 mm, electronic
        Valvetrain DOHC, 4 valves per cylinder
        Valve diameter Intake: 37.0 mm
        Exhaust: 32.0 mm
        Pistons Forged aluminum
        Connecting rods Cracked forged steel I-beams
        Ignition Coil-on-plug
        Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
        Displacement 330 cu. in. / 5,409 cc
        Horsepower More than 450
        Torque 450 lb.-ft
        also will be running stock at about 8.5 PSi
        06 Zo6
        427 cid Aluminum C5R blueprinted block
        512HP with advertised 500HP
        Aluminum block w/104.8mm bores & pressed-in liners
        Forged steel crankshaft with 101.6mm stroke
        6-bolt forged steel main bearing caps
        Titanium connecting rods
        Cast Eutectic aluminum flat-top pistons
        Racing-derived CNC-ported aluminum heads w/ 70cc chambers
        56mm titanium intake valves
        41mm sodium-filled exhaust valves
        11.0:1 compression ratio
        Composite manifold with 90mm single-bore throttle body
        Camshaft with 15mm (.591-inch) lift
        Dry-sump oiling system
        7000rpm redline
        Weight: 2900 lbs
        Rear spoiler
        Functional air induction from hood vent
        Hydroformed aluminum chassis*
        • 94NDTA9
          94NDTA9
          The Z06 is 3030 specifically, and has more HP and TQ. Most places I have been reading have said the curb weight of the Gt500 is around 3600 lbs.
          HERE IS ONE OF THEM
          They are NO WHERE in the same league, especially in the handling department.
          • Pony_RacerP
            Pony_RacerP
            Pony_Racer
            was talking about the 99 not the new Z06 :D....my bad
            • Pony_RacerP
              Pony_RacerP
              Pony_Racer
              also price of the GT500 will be around 40k.
              Z06 is estimated 50-70k.......
                lingenfelter corvette owns all...0-60 in 1.8 seconds??
                • Pony_RacerP
                  Pony_RacerP
                  Pony_Racer
                  http://www.fast-autos.net/ford/fordbossmustang.html
                  1.9...not bad for a heavy stang 😄
                  and actually the vette was 1.9 too 😄
                  http://www.fast-autos.net/lingenfelter/lingenfelter427tt.html
                  • 94NDTA9
                    94NDTA9
                    I would take my car to ARE before LPE.
                    • P
                      P
                      pjm710
                      I was thinking the vett and then next summer going with a procharger at like 5 or 7 psi. insurance not a problem its around 100 month for me.
                      Its not where the car came from its how fast it can get away from there
