  2. Introductions
  3. Introductions
  4. First Time
First Time
34 Posts 14 Posters 2.8k Views
  • Pony_RacerP
    Pony_RacerP
    Pony_Racer
    you wouldnt even need to throw a blower on a vette to beat a GT.....but if its a 99 vette that your getting average price tag is probaly around 25-30k depending on seller and etc. and 05 GT's are actually around the same price if you look.
    1999 Corvette specs...
    • 5,665 cc 5.7 liters 8 V front longitudinal engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, light alloy block, light alloy head, overhead valve and two valves per cylinder
    • Premium unleaded fuel
    • Fuel economy EPA highway (l/100km): 9.4
    • Multi-point injection fuel system
    • 72 liter fuel tank
    • Power: 345 HP @ 5,600 rpm; 350 ft lb , @ 4,400 rpm
      vs. 05 GT
    90° Aluminium Block and Heads
    Gear chain-driven SOHC, 3 valves/cyl, hydraulic lifters, variable intake- and exhaust-valve timing
    281 CI / 4606 CC
    300 BHP / @ 6000 RPM
    315 FT LBS / @ 4500 RPM
    6000 RPM
    Bore 3.55 IN / 90 MM
    Stroke 3.54 IN / 90 MM
    9.8:1 compression
    Aluminum block and aluminum heads
    So based on those #'s vette=faster....but both have = tuning capabilities and just depends if your a ford guy or chevy 😄
    both also come stock with great handiling.
    vette=
    Wishbone front suspension with stabilizer bar independent with leaf springs , multi-link rear suspension with stabilizer bar independent with leaf springs
    GT Front suspensions set up-MacPherson struts, coil springs, anti-roll bar
    Rear-Rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar.
    R.I.P 1QK_PNY:icon_salut:
    • FlowcusF
      FlowcusF
      Flowcus
      In the long run I think the stang would take the vette out. Lower compression stock, with valve timing and more valves per cyl.
      Not to mention the stang is probably lighter then the vette. And the new 06 mustang GT500 is going to kill the new vette ZO6 ( detuned version of the 5.0 in the ford GT supercar in the new GT500 otherwise known as the SVT Cobra )
      I ride random bitches.
      • 94NDTA9
        94NDTA9
        I disagree with everything you say here.
        • 94NDTA9
          94NDTA9
          The new Z06 will be right on the heels of the Ford GT. It weighs over 200 lbs less, only 50 less hp, 25 less lbft of TQ, Has a better weight distribution, and has allready provne in the C6 models, that it handles remarkable.
          The only thing the GT500 will be competing with will be the new GTO.
          Just wait till GM puts FI on the C6 Z06 🙂
          • Pony_RacerP
            Pony_RacerP
            Pony_Racer
            05 GT is about 3,400lbs vette is around 3200 or so. But then again the vette was aerodynamically built for racing where as the GT was not completely designed for that purpose hence the weight differences.
            • Pony_RacerP
              Pony_RacerP
              Pony_Racer
              07 GT 500 specs....
              V-8
              Manufacturing location Romeo, Michigan
              Configuration Iron Block and Aluminum Heads
              Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
              Exhaust manifold Cast iron
              Crankshaft Forged steel
              Throttle body Dual 55 mm, electronic
              Valvetrain DOHC, 4 valves per cylinder
              Valve diameter Intake: 37.0 mm
              Exhaust: 32.0 mm
              Pistons Forged aluminum
              Connecting rods Cracked forged steel I-beams
              Ignition Coil-on-plug
              Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
              Displacement 330 cu. in. / 5,409 cc
              Horsepower More than 450
              Torque 450 lb.-ft
              also will be running stock at about 8.5 PSi
              06 Zo6
              427 cid Aluminum C5R blueprinted block
              512HP with advertised 500HP
              Aluminum block w/104.8mm bores & pressed-in liners
              Forged steel crankshaft with 101.6mm stroke
              6-bolt forged steel main bearing caps
              Titanium connecting rods
              Cast Eutectic aluminum flat-top pistons
              Racing-derived CNC-ported aluminum heads w/ 70cc chambers
              56mm titanium intake valves
              41mm sodium-filled exhaust valves
              11.0:1 compression ratio
              Composite manifold with 90mm single-bore throttle body
              Camshaft with 15mm (.591-inch) lift
              Dry-sump oiling system
              7000rpm redline
              Weight: 2900 lbs
              Rear spoiler
              Functional air induction from hood vent
              Hydroformed aluminum chassis*
              • 94NDTA9
                94NDTA9
                The Z06 is 3030 specifically, and has more HP and TQ. Most places I have been reading have said the curb weight of the Gt500 is around 3600 lbs.
                HERE IS ONE OF THEM
                They are NO WHERE in the same league, especially in the handling department.
                • Pony_RacerP
                  Pony_RacerP
                  Pony_Racer
                  was talking about the 99 not the new Z06 :D....my bad
                  • Pony_RacerP
                    Pony_RacerP
                    Pony_Racer
                    also price of the GT500 will be around 40k.
                    Z06 is estimated 50-70k.......
                      lingenfelter corvette owns all...0-60 in 1.8 seconds??
                      • Pony_RacerP
                        Pony_RacerP
                        Pony_Racer
                        http://www.fast-autos.net/ford/fordbossmustang.html
                        1.9...not bad for a heavy stang 😄
                        and actually the vette was 1.9 too 😄
                        http://www.fast-autos.net/lingenfelter/lingenfelter427tt.html
                        • 94NDTA9
                          94NDTA9
                          I would take my car to ARE before LPE.
                          • P
                            P
                            pjm710
                            I was thinking the vett and then next summer going with a procharger at like 5 or 7 psi. insurance not a problem its around 100 month for me.
                            Its not where the car came from its how fast it can get away from there
