  4. Plug Gap
Plug Gap
16 Posts 9 Posters 688 Views
    pin
    .060-.064 should give a nice big spark.
    Barry
      i mean .028-.030....yeah but im running boost and that big of spark will blow out
      • 94NDTA9 Offline
        94NDTA9 Offline
        .35 is basically the max I would use on any FI or N20 application.
          yeah i got it at like .029
          • XJHEADX Offline
            XJHEADX Offline
            Keep opening them up till they blow out....
              no more than .32. actually, the reason that you want the smaller gap is because you want a pretty small spark. why? i can't remember... but a big gap (+.35) can result in pretty nasty misfiring, i know from experience.
              if you use a platinum plug, they've been known to misfire. why? because the combustion chamber is REALLY hot, platinum and iridium stay hotter longer than copper and may cause misfiring to occur.
              • 94NDTA9 Offline
                94NDTA9 Offline
                Don't go higher because cars with high cyl pressure will blow out the spark.
                • XJHEADX Offline
                  XJHEADX Offline
                  Fargo wrote:
                  Keep opening them up till they blow out.....
                  • 9 Offline
                    9 Offline
                    95TsiAWD
                    How much boost are you running and is it just pump gas?
                    95 TSi AWD
                    Old Turbo #'s
                    522whp/414wtq
                    [email protected]
                    11.3@129mph
                    Procharged 99 Corvette
                    95 LS6 Mustang
                    01 300m
                    06 Suzuki LTR-450
                      15psi pump gas
                        see how far you can make the gap and then try running it and see what happens.
                          Run .028 and you will be fine.
                          On my integra on pump gas and low boost I run .028-.030 and on race gas and 30+ psi I run .025.
                          • 91nbtsi9 Offline
                            91nbtsi9 Offline
                            As everyone else has said, run around .028". I had to run down to .022" on 35psi and 8000rpm to get my car not to blow the spark out. But, until you are running that much boost and stuff, keep it at around .028".
                              thanks guys!
