  4. Plug Gap
Plug Gap
16 Posts 9 Posters 877 Views
  • XJHEADX Offline
    XJHEADX Offline
    Keep opening them up till they blow out....
      no more than .32. actually, the reason that you want the smaller gap is because you want a pretty small spark. why? i can't remember... but a big gap (+.35) can result in pretty nasty misfiring, i know from experience.
      if you use a platinum plug, they've been known to misfire. why? because the combustion chamber is REALLY hot, platinum and iridium stay hotter longer than copper and may cause misfiring to occur.
      • 94NDTA9 Offline
        94NDTA9 Offline
        Don't go higher because cars with high cyl pressure will blow out the spark.
        • XJHEADX Offline
          XJHEADX Offline
          Fargo wrote:
          Keep opening them up till they blow out.....
          • 9 Offline
            9 Offline
            95TsiAWD
            How much boost are you running and is it just pump gas?
            95 TSi AWD
            Old Turbo #'s
            522whp/414wtq
            [email protected]
            11.3@129mph
            Procharged 99 Corvette
            95 LS6 Mustang
            01 300m
            06 Suzuki LTR-450
              15psi pump gas
                see how far you can make the gap and then try running it and see what happens.
                  Run .028 and you will be fine.
                  On my integra on pump gas and low boost I run .028-.030 and on race gas and 30+ psi I run .025.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    As everyone else has said, run around .028". I had to run down to .022" on 35psi and 8000rpm to get my car not to blow the spark out. But, until you are running that much boost and stuff, keep it at around .028".
                      thanks guys!
