  4. Wont start
Wont start
22 Posts 12 Posters 942 Views
    Posted this on Tintmasters, but i figured ide post here too.
    So I was out cruising 2 or 3 weeks ago, and all of the sudden my car started to act funny. I parked it, and when i came back 1/2 hour it wouldn't start. I check for spark and fuel, had both.
    SO I towed it back, while hooking up my tie-downs on my trailer, i noticed that my turbo was VERY loose on my manifold. i haven't done anything with it, but I would like to know what is wrong with it before I dig into it. Could it be that since my turbo is literally hanging on my manifold, that it doesn't spool, therefore not giving me any air? THis is the only solution that I could come up with. If the turbo isn't spinning at all, is it getting any air?
      slowvo
      It will still start even if the turbo is frozen.
      after fuel and spark, do you have inj. pulse? is your timing right? did the TB jump?
      ecu fried?
        how do you think n/a motors start without a turbo...its magic. does it even crank?
        • camzaro28C Offline
          camzaro28C Offline
          camzaro28
          couldnt be because u have a FORD could it? 😉
          jig 4 prez
            Yes, it sputters and wants to start. it turnos over and dies as soon as I let off the cranking switch. If it helps I tried various different positions with the throttle too, but it doesnt seem like stepping on the gas makes any difference.
              dont touch the gas on a fuel injected car...it will flood
              • XJHEADX Offline
                XJHEADX Offline
                Not true.....
                  well not all the time...but thats a good way for it to flood especially if its not starting
                  • XJHEADX Offline
                    XJHEADX Offline
                    Holding throttle to the floor shuts down all inj pulse.
                    • GarageAlchemistG Offline
                      GarageAlchemist
                      watch your self
                      97 GTi, 03 KJ
                      • My NOvaM Offline
                        My NOvaM Offline
                        My NOva
                        agreed^^^^
                        Hey Tina come get some hamm
                          slowvo
                          if thats true, why does my car start if i hold my pedal to the floor then crank it over?
                          dont say things that are untrue. well it may be true for some cars, but defenitly not all
                            I don't need any more advice, just "sold" the car as a parts car. should have it gone in a couple weeks.
                            • ticklemedalyT Offline
                              ticklemedaly
                              Cool you sold the car, but as for the throttle part, every vehicle is different. MOST newer vehicles will kill the inj. pulse when you hold the pedal at full throttle. Older fuel inj. vehicles will flood the car. It is highly recommended not to touch the gas on any vehicle unless it is carburated. Or unless you know what you are doing.
                              XBL G-tag: TickleMeDaly83
                                joel so that mean icant buy your fmic anymore? so so sad, but no use for it for 6months
                                • theobliviousT Offline
                                  theoblivious
                                  how much you selling it
                                  BOOST....to be continued
                                    I've taken 2 electronic/engine performance(with a month or so of fuel pumps/filters/etc) classes at my HS. I knew what was doing.
                                      what i wanted for it. I got atleast what i have into it for money. as for time, well it was worth about 50 bucks evidentally. oh well, it was fun.
                                        ticklemedaly
                                        I'm not saying that you may not know what you are doing....Im just telling what my knowledge is based on....Im a master certified auto technician, and I stated the rule of thumb for those who dont know what they are doing.....im not trying to do a pecker measuring contest here either.
                                          cool. BTW nice car. Thinking about that or a Si for my next car.
