  4. loose carbs?
loose carbs?
33 Posts 11 Posters 1.6k Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    Gotta question, lets see if anyone has an idea. My bike is running kinda funny under 7,000. As soon as I hit around 7,000 it takes off and works normal. I asked a few bike people and mechanics and they think that my carbs might be loose and sucking in extra air. Other people think it might be something to do wiht the fuel system. Any ideas??
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
    • Roller28R Offline
      Roller28R Offline
      Roller28
      Carbs work on two Jets, Main Jet and needle jet. One jet is for higher RPM's and the other is for lower RPM's. It sounds to me you are having a fuel problem with either your entire setup. What are you running for exhaust, intake, jetting? With carburation, everything has to be on the same page to work properly. Have you installed a jet kit?
      1987 Toyota Pickup 4X4 (lifted)
      1999 Honda CBR900RR
      2001 Yamaha Raptor 660
      2006 Honda Civic Coupe (wife's)
      Wife with Bolt on's, what else could you ask for?
      • Roller28R Offline
        Roller28R Offline
        Roller28
        also what are you using for fuel? No matter what, you ned to be running the highest grade fuel possible for optimum performance. No exceptions what so ever.
        1999 Honda CBR900RR
        • jct_4628J Offline
          jct_4628J Offline
          jct_4628
          everything is stock except for a KN filter and a Vance and Hines exhaust.
          Jason
          -06 WRX
          -95 CBR 600F3
          701-541-2568
            Damn when I saw this in new posts, i thought by the title that it would help me take aoff a few pounds.
              Me too, god knows I could use it. Sorry for whoring.
              • 2wheeler2 Offline
                2wheeler2 Offline
                2wheeler
                Please explain "grade". Are you speaking of octane levels?
                '08 Suzuki Hayabusa
                '09 Yamaha Zuma 200cc
                '95 E-350 7.5L
                • Roller28R Offline
                  Roller28R Offline
                  Roller28
                  so then you need to re jet the bike because it needs larger jets to work properly with the more air flow, and free flowing exhaust. I sell jet kits here in CA.
                  1999 Honda CBR900RR
                  • Roller28R Offline
                    Roller28R Offline
                    Roller28
                    yes octane levels, they call it grade of fuel such as 89, 90, etc..
                    1999 Honda CBR900RR
                    • 2wheeler2 Offline
                      2wheeler2 Offline
                      2wheeler
                      Then I'm gonna have to disagree with you. For highest performance, I would go with a fuel such as VP MR9. It's 87 octane, but you'll prolly see a good 5-10 HP on a dyno with no fuelling changes.
                      '08 Suzuki Hayabusa
                      '95 E-350 7.5L
                      • Roller28R Offline
                        Roller28R Offline
                        Roller28
                        Whats to disagree with? I was just telling him about the grades of fuel, not what grade to put in the bike!
                        1999 Honda CBR900RR
                        • Roller28R Offline
                          Roller28R Offline
                          Roller28
                          How can you get 5-10 hp out of an 87 octane fuel? Explain...............................
                          1999 Honda CBR900RR
                          • Roller28R Offline
                            Roller28R Offline
                            Roller28
                            First of all, in a street bike you do not want to run straight race gas, you want to mix it 50/50. I have seen way to many engines take a crap because it can not hold up to that gas. GP bikes run this gas for a reason, because the engine can handle it. I still don't see someone getting 5-10 hp from the gas, do you realize how hard it is to squeeze more HP from these bikes, esecially a carburated one! If you are the average rider on the street, just run the top pump octane you can buy, otherwise you are wasting your money.
                            1999 Honda CBR900RR
                            • 2wheeler2 Offline
                              2wheeler2 Offline
                              2wheeler
                              Unfortuately, you're wrong. MR9 is highly oxygenated and that is how it makes power. As far as using it on street bikes, it is just fine. It will cause no damage. A friend of mine, Robert Jensen, who is the current F-USA road racing champoin in both the superbike and superstock classes uses it in his bikes. They are both limited to STOCK internals. His CR is raised to somewhere around 14:1 and he uses MR9(87 octane) in both, and they hold up fine. He sees around a 10 RWHP gain with that fuel.
                              As far as straight race gas, what fuel are you speaking of? VP makes over 30 different fuels alone.
                              And engines taking a crap from race gas? That one is new to me. The only bad thing about a fuel that I've seen is how Nutec will eat through fuel lines if not purged each day.
                              Oh yeah, and just this spring, Arcane Racing "squeezed" 701 HP from a Hayabusa. Stock was prolly 155-160. So, there's some room to move in the HP department.
                              '08 Suzuki Hayabusa
                              '95 E-350 7.5L
                                Ethan is right, and I gotta chime in here too. Fist off, high octane fuel doesn't make more power by itself, in fact since its harder to burn it may make less power. What high octane fuel does do it reduce knock. That is all the octane ratings really mean.
                                So, you're now probably asking why use high octane fuel if it doesn't add power? The answer is simple: It reduces knock which adds a layer of safety to an aggressive tune. For example, lets say that you can squeeze 200 whp out of a vehicle on pump gas w/ 18 psi of boost before knock, you should be able to run a bit leaner and/or turn up the boost and/or advance the timing if you run C16 which should in turn get you to a higher whp.
                                • FlowcusF Offline
                                  FlowcusF Offline
                                  Flowcus
                                  Funny guy... Word of advice. Dont argue with ethan about bikes, you wont win.
                                  I ride random bitches.
                                    what he said^^
                                    • jct_4628J Offline
                                      jct_4628J Offline
                                      jct_4628
                                      I put some sea foam in there...seems to be working better.....
                                      Jason
                                      -06 WRX
                                      -95 CBR 600F3
                                      701-541-2568
                                      • Roller28R Offline
                                        Roller28R Offline
                                        Roller28
                                        I guess I should not try to compete with you, since you are so knowledgeable about bikes, right? Whatever. This is not a competition what so ever, I was just trying to help someone out, and you took it way out of context. He has a jetting problem, not a fuel problem. And not to mention it is a carburated CBR 600, it is not ment for a speed demon, it is ment for riding. Come on people, quit trying to prove you are so knowledgeable, and enjoy the motorcycle for what it is ment for, RIDING! O, I forgot you can only ride 3 months out of the year there! This is not a pissing contest, I was just trying to help someone out. Come out here to California and ride with me sometime, then we will have a pissing contest!
                                        1999 Honda CBR900RR
                                          In Roller28's defense, ^ how is this not true? It was my understanding that higher octane fuel was recommended for a bike like jct's.
